Hood fitting--body men please reply
Old Oct 18, 2004 | 05:44 PM
foundvettelifeisgood's Avatar
Default Hood fitting--body men please reply
I fitted my Eckler's L-88 hood yesterday. It went well, but the fenders will need to be cut along the inner ledge to bring the fenders up to the hood level in certain areas. Anyone ever do this? Eckler's directions say to use a putty knive in 1/8 inch increments to separate the inner skirt from the fender, then raise the fender from underneath and putty the gap. Sounds a little intimidating. Would a cutting wheel from inside the wheel well work better or worse?
Old Oct 18, 2004 | 08:18 PM
ttt and here's some pics
Old Oct 18, 2004 | 08:33 PM
LT1driver's Avatar
LT1driver
if they recommend that i would send it back , bad company in my opinion.
Old Oct 18, 2004 | 08:41 PM
Roadster71's Avatar
Roadster71
Don't cut anything. The joint that they are talking about overlaps, so there is a place to bond together. If you cut them apart there won't be anyway to bond them! Where exactly is the hood higher, sides? front? What you may have to do, is a white knukle operation on a finish painted car!
Old Oct 18, 2004 | 09:39 PM
Your no-cut advise sounds good. Thanks.
The hood is slightly high along the passenger side seam near the center of the hood. After sanding both side edges of the hood near the front hinges and messing with the shims, the hood's fit and gaps are very good.
The car needs a re-paint. I had no illusions of simply painting the hood to match. This separation adjustment seems reasonable, and probably wouldn't phase a bodyman.
I'm still holding out for some encouragement and pics. The Eckler's directions show pics, but they are of very poor quality and can't make them out. I probably need to study the joint. Anyone have a pic of the inner fender before it's bonded to the outer fender?
Old Oct 18, 2004 | 11:32 PM
enforcer's Avatar
enforcer
Have you tried removing (or adding) the rubber block hood spacers along the hood opening?
I have a book called "Ecklers complete guide to fiberglass repair" showing that operation to bring the fenders up slightly. Its an excellent book and covers lots of c-3 problem areas. You might want to find you a copy somewhere.
Old Oct 19, 2004 | 06:04 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
A lot of L-88 hood buyers found that our hinges were a culprit, causing the hood to sit up higher than it should.
Old Oct 19, 2004 | 09:33 AM
CGGorman's Avatar
CGGorman
My NOS L-88 hood does not match the fender contour on either side near the center. I considered fixing it, but it would mean altering one or both, the fender and hood. Both are original. I'm just gonna leave them alone and work with hinge height, which is a little high. If anybody gives me guff, I'll just tell'em the general made it that it way. Hey, it's the truth.
Old Oct 19, 2004 | 11:13 AM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
I know this is no help, but mine fit perfectly with no modification to the hood or the car.
Old Oct 19, 2004 | 11:37 AM
73 Vet's Avatar
73 Vet
OHSIXX: Where did you get your hood?
Old Oct 19, 2004 | 03:03 PM
NHvette's Avatar
NHvette
Definitely agree with "no cut".
If you need to separate, do it at the original bond seam.
Will this F-up the fiberglass ? no. They were glued together
at the factory - just use the right adhesive.
Before you start splitting any seams, definitely mess with
hinges and spacer blocks. Getting the hood sitting on the
spacers can push the low areas high and the high areas low.
Good luck
Old Oct 19, 2004 | 04:00 PM
OHSIXX's Avatar
OHSIXX
Ecklers during one of their 10 percent off everything sales.
A friend of mine helped me. We had the old one off, changed the latches, and installed the new one in well under 30 minutes.
My original hood use to drop shut. The L88 will drop shut on the drivers side, but I have to manually press it in on the passengers side. Good luck with yours.
Old Oct 19, 2004 | 05:51 PM
The hinges are fine. The hood fits very well at all 4 corners. The stock SB hood had 4 shims on the drivers side front hinge and 2 on the passenger side and it fit very well. I removed one shim from under each hinge and the hood is about dead on with the nose/headlight area.
The issue I'm having is the same as CGGorman's NOS, and the Ecklers instructions address it, so it must be common. Breaking the seam looks like the way to go, because you couldn't alter the hood contour. The hood is first quality.
Sounds like I need the Ecklers book or DVD on bodywork. I'll bet the guys who've done scoops and flares wouldn't flinch at this "adjustment". Why couldn't Len be a bodyman instead of a BB builder?
Old Oct 19, 2004 | 07:23 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
ive never heard of cutting the body to fit the hood. that seems kinda drastic. i got mine from ASCD a couple years back (they sold thier molds to vanacorvette) and mine fit like a glove after some hinge manipulation.
Old Oct 19, 2004 | 11:58 PM
codestar7's Avatar
codestar7
Default Fit and Finish
Absolutly the touphest part of fiberglass is making everything fit and flow.
Old Oct 20, 2004 | 04:40 AM
comp's Avatar
comp
no cut New hood Love that green
Old Oct 20, 2004 | 08:04 AM
bracketshark's Avatar
bracketshark
Default L-88 hood
I put this same Eckler's hood on my 71 coup. had to raise the fender on the passenger side slightly to make it fit better. Once the skirt and fender are seperated we moved the fender up (not hard at all) and used 1 pop rivit to hold it in place, there was really not that much to the procedure, some of the later 70's I've noticed have a rivit on both sides holding the fender in place on the skirt. One thing you might check, with the skirt and fender serparated, if you loosen the radiator support bolts on the side that needs adjustment you might be able to lower the hood instead raising the fender. I really like these hoods, it is a quality piece, I've also delt with Eckler's a long time and they are eager to help with their prducts, if there is a problem.
To Hood fitting--body men please reply
Old Oct 20, 2004 | 06:19 PM
Did you do the separation using the putty knife technique Eckler's mentions? Did you take any pictures?
Old Oct 20, 2004 | 11:10 PM
454Can-Am's Avatar
454Can-Am
I don't understand the technique you're talking about here, but from trying to adjust mine what I did was loosen the bolts that support the front frame piece (while supporting each side with a jack) and lower it down till the hood is even with the fenders in the middle ! Worked for me !!! Rick
Old Oct 20, 2004 | 11:34 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Heck, the stock hood on my '77 L48 doesn't fit right. The fenders are a bit too high in the middle. It's the kind of thing that no one but a Corvette expert or someone who's worked on the car for over half of his life would notice.
