Cage nut ????
Old Oct 19, 2004 | 05:41 PM
nd4speed's Avatar
nd4speed
Default Cage nut ????
Got cage nuts today. How should i go about putting them on. is everything tack welded together then weld to frame?
Old Oct 19, 2004 | 05:48 PM
Red 69's Avatar
Red 69
If you are talking about the cage nuts for body mount #2 and #3, just center them over the hole in the frame and weld both sides of the cage to the frame.
Old Oct 19, 2004 | 11:20 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
The nut is free in the cage. The only weld is the cage gets welded to the frame.
Old Oct 20, 2004 | 12:35 AM
68/70Vette's Avatar
68/70Vette
The number 4 nut cages are riveted to the number 4 mounting bracket with the fiberglass body panel sandwiched in between. The rivets are aluminum. If I were doing a body off resto, I'd think about using steel rivets or stainless steel screws instead of the rivets. The aluminum rivets will shear easy, making it difficult to remove the number 4 nut.
To Cage nut ????
