Frame interchangeability
Old Oct 20, 2004 | 04:14 AM
corvettecris's Avatar
corvettecris
Default Frame interchangeability
I was just curious if anyone had any good leads on the frame interchangeability on a 68. My frame is pretty bad, and I'd like to just get a new one. I was assuming that a 68-72 frame would work just fine, but some agree and some disagree. I was wondering if anyone has done this before, or has any good research on the topic. The only changes I am aware of on the 68-72's are a kickup gussets.
Also, I know the 68 year radiator support assembly was unique. Do you think a non-68 frame will call for switching to a non-68 radiator support?
Old Oct 20, 2004 | 04:32 AM
comp's Avatar
comp
i think there was a post a couple of days ago
Old Oct 20, 2004 | 08:14 AM
corvettecris
I did a search before I posted, with no results. Any idea on the topic of the post?
Old Oct 20, 2004 | 08:23 AM
stpman's Avatar
stpman
Check this out
http://www.71corvette.com/frames.html
Steve
Old Oct 21, 2004 | 01:43 AM
corvettecris
I read that, but the only thing I didnt like is the fact that that information wasn't referenced. I have no idea who wrote that article, and what their qualifications are. I also am concerned because that information contradicts what a corvette salvage yard I contacted told me. They say a 68 frame is unique, and no other frame will work. The reason I want a second opinion is because the salvage place charges more for a 68 over any other c3, and I wonder if they're telling me that just to rip me off...
I just dont want to buy a non-68 frame, and be stuck with a huge, expensive piece of scrap because it wont fit.
Thanks for the input so far. As soon as I get to the bottom of this, i will post all I learnfor the entire vette community to benifit from.
Old Oct 21, 2004 | 08:42 AM
Smokin Joe's Avatar
Smokin Joe
Check with Cannon's Corvettes in North Carolina. They do a lot of corvette frame stuff.
Old Oct 21, 2004 | 10:12 AM
markdtn's Avatar
markdtn
Pretty sure 68-72 interchange. Where in the country are you?
Old Oct 21, 2004 | 10:52 PM
crf311's Avatar
crf311
I think they only added some support on the 69 and later. Their is a differance between the 4speed and automatic frames.
Old Oct 22, 2004 | 03:19 AM
corvettecris
Thanks for the info. I am contacting Cannon Corvettes shortly. I will post what I find out.
I live in San Diego, by the way (Currently deployed to Iraq)
Old Oct 22, 2004 | 09:32 AM
LemansBlue68's Avatar
LemansBlue68
The '68 frame WILL interchange with '69-'72. Late '68 frames have the additional kick-up gussets and are essentially the same as '69-'72 frames. As noted, manual trans frames have the trans crossmember welded in, the auto trans frames have the cross-members bolted in. The '68 radiator support is unique but switching frames won't require a new radiator support. In fact, the radiator support does not even attach to the main portion of the frame. There is a bolt on front cross-member that the post-'68 radiator supports bolt to, but in the '68's that same cross-member does not have the rad support attaching holes so is unique in that respect. Later cross-members will work though if your cross member is rusted out (you will find that many are). A source for Corvette frames out in Cali is Crane's (in San Diego) and J&D (not sure where in Cali they are located but they advertise in a lot of the Corvette mags).
Stay safe in Iraq!!! We want you back healthy and soon!!
Old Oct 22, 2004 | 10:09 AM
nhlgopens's Avatar
nhlgopens
Zip Corvette Products carries a repro 68 frame for manual tranny $4095 (part # SU-750) or auto tranny $3795 (part # SU-749).
Old Oct 22, 2004 | 12:39 PM
corvettecris
Now that's what I call a lead on some good info! Its expensive, but not much more thatn the quotes I've gotten on reconditioned frames. I will keep that option in mind if I cant find a better solution. I just wish it wouldnt put such a hole in my finances....
Old Oct 22, 2004 | 12:48 PM
nhlgopens's Avatar
nhlgopens
That's what we are here for... good luck and stay safe in Iraq. Our prayers are with you...
Old Oct 22, 2004 | 01:17 PM
JLMvette73's Avatar
JLMvette73
Take a look at CorvetteUSA. They're in Ramona, California.
http://www.corvetteusa.com/frames.html
Old Oct 22, 2004 | 02:12 PM
crf311's Avatar
crf311
Keep an eye out for a used frame. I have run across some for around 1-2k. Best of luck and stay safe. And thanks for your part in keeping our country free and safe.
Old Oct 22, 2004 | 03:07 PM
crf311's Avatar
crf311
Justseen this on corvette society web site
2004-10-13 74 Corvette 4 Speed bare frame, no rot needs alittle work. $950.00 e-mail (winchy1@aol.com) N.Y. area.
Old Oct 23, 2004 | 01:31 PM
corvettecris
The best info so far (for me) is the CorvetteUSA in Raymona, CA. I checked out their website, and the prices seem very reasonable, compared to other prices I've gotten.
Thanks for everyone's help and support.
To Frame interchangeability
