Can someone please post a picture of a stock 73 L-48 motor so I can see the vacuum line routing. I have one hard line coming out of carburator not hooked up. Also I have a T with one line missing.I can't figure out how to upload pictures to show u what I'm talking about. Thanks
I will have a look at mine in the morning and take a picture of it. I have just removed the smog pump so there is a hose connecting both sides of the exhaust manifolds together where the smog stuff used to be but other than that it's all stock.
Thanks I appreciate that. Are you going to remove the air tubes also? Just debating on removing my smog pump its siezed up right now.But I don't know how tuff it is to remove the air tubes.
AIR tubes are plumbed into the manifolds. Best to either:
A) replace the manifolds with something better. Headers will pick up power. No doubt. Or go with the 2.5" rams horns, they do not have AIR fittings.
B) Buy threaded pipe ends. You can remove the AIR valves where the hoses attach to and thread caps on both sides. That'll make it look cleaner for now.
My plan is to remove the air tubes this winter when I pull the engine out to detail the engine and engine bay. I was going to install plugs in the threaded holes and leave it like that. The way mine was done there wasn't anything connected to the smog pump so it was easy to remove it.
If you do decide to put plugs in there, try to find STRAIGHT pipe thread plugs. The holes/fittings are not the typical NPT tapered pipe threads that you find at the hardware store. The threads are actualy straight. You can trash the threads for any future use by installing the wrong plugs.
This might not matter to you now but maybe someday or some future owner would care. Just a thought.
-Mark.
If it is not tapered, it is not a pipe thread (NPT). Wherever there is a tube with a flare connected, you need a flare plug - not a pipe plug - to eliminate the tube.
Take a look at an industrial tool vendors catalog in the pipe tap section. There are both tapered pipe threads and straight pipe threads. Straight pipe threads are not as common as tapered pipe threads but that was the reason for my post. I can point you in the right direction if needed. I would hate to see another pair of manifolds trashed because someond did not know any better. There IS a difference.
