C3 Coil-overs
Old Oct 21, 2004 | 11:19 AM
johnboy89's Avatar
johnboy89
Default C3 Coil-overs
Who sells coil-overs for C3's
Old Oct 21, 2004 | 11:21 AM
Twin_Turbo's Avatar
Twin_Turbo
No one sells true coil overs for the C3 except Jim Meyer Racing, the others that sell systems that are advertised as coil overs sell semi coil overs.
If you are serious about doing it and do not want to build your own system I suggest you look into the Jim Meyer Racing setup, the arms, coil overs & other items look to be of excellent quality. I would use their system if I wasn't building my own.
Old Oct 21, 2004 | 11:33 AM
johnboy89's Avatar
johnboy89
here's the link
http://www.jimmeyerracing.com/cv7.html
Old Oct 21, 2004 | 11:42 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I have the semi coilovers that TT is talking about
http://www.vansteel.com/index.cfm?fu...&SubGroup=1913
Old Oct 21, 2004 | 11:50 AM
Twin_Turbo's Avatar
Twin_Turbo
do a search, the coil over susp. is not depicted on their site but recently there was a thread about them and the pics are in there.
Old Oct 21, 2004 | 12:10 PM
johnboy89's Avatar
johnboy89
What's the difference between the two - thanks
Old Oct 21, 2004 | 12:16 PM
Van Steel's Avatar
Van Steel
true coilover have eyelets on both top and bottom. If you want to run that you'll have to fab up plated to weld in your spring pockets. Mine are bolt on. You only have to drill the shock mounting nuts out to a 3/8 od.
Old Oct 21, 2004 | 12:41 PM
johnboy89's Avatar
johnboy89
Thanks for the heads up VS - looks like a nice product.
Old Oct 21, 2004 | 01:08 PM
Van Steel's Avatar
Van Steel
Thanks and no problem.
Old Oct 21, 2004 | 01:51 PM
norvalwilhelm's Avatar
norvalwilhelm
I did true coil overs last winter and unless you are a good fabricator/welder don't do it. To do it properly involves alot of cutting/fabricating mounts/welding plates over the cut out springs pockets and is just to difficult for the average hot rodder.
Old Oct 21, 2004 | 01:53 PM
81 Vette's Avatar
81 Vette
St. Jude Donor '05
First C3 General Poster!
Im still slightly confused as to the difference in the two systems, and the difference when compared to a system like the Eckler's uber suspension package of d00m...they all seem to have the A arms, adjustibility and whatnot... ...Im trying to get the best setup but am having a helluva time picking one.
Old Oct 21, 2004 | 02:01 PM
norvalwilhelm
True coil overs are a shock with the spring trapped between the top mount of the shock and the body of the shock with is adjustable ring. You can put the spring on the shock, tighten it up on the bench and then just slide it into place.
The semi coilover doesn't hold the spring top and bottom. The top of the spring rests in the stock spring bocket and the bottom is held by the shock body. If you releace the shock the spring can fly out.
I can pull the top and bottom shock mounting bolts and lift the spring/shock out to change the spring on the bench. The spring is totally trapped within the shock
If you release the bottom of the semi coilover the spring can go flying like stock.
While the semi coilovers are also a total bolt in true coilovers require alot of cutting/welding
Old Oct 21, 2004 | 02:03 PM
81 Vette's Avatar
81 Vette
St. Jude Donor '05
How much of an advantage are you going to get in the slalom and G pad using a coilover kit as opposed to the high end Eckler kit? IN THEORY
Old Oct 21, 2004 | 02:08 PM
Van Steel's Avatar
Van Steel
I don't like the idea of a front monospring. Been there, done that. I believe you will get a much better ride out of a coilover shock or semi-coilover shock set up.
Old Oct 21, 2004 | 02:17 PM
norvalwilhelm
I don't like the monospring either. I believe it is a step backwards, tying the front end together. Harmonics in the spring travel from one side to the other.
Old Oct 21, 2004 | 02:29 PM
81 Vette's Avatar
81 Vette
St. Jude Donor '05
hrmph....so the best option would be doing composite monos in the back, with updated springs, shocks, sways, bushings, arms, all the good stuff, then building a coilover system in the front...interesting. I wonder how much MORE thatll cost me hahaha.
Old Oct 21, 2004 | 03:02 PM
CGGorman's Avatar
CGGorman
No, this would be BEST:
'Course, you would have to mount in on a different frame to take advantage of it...
To C3 Coil-overs
Old Oct 21, 2004 | 03:08 PM
Twin_Turbo's Avatar
Twin_Turbo
I have a picture of a truck with a C4 rear suspension and pushrods/rockers. He used bags but you could convert it to coil overs...lemme search, it was quite a nice setup.
Old Oct 21, 2004 | 03:10 PM
CGGorman's Avatar
CGGorman
This would be real easy to implement:
Twin_Turbo's Avatar
Twin_Turbo
Found it!!!
