My garage is underground and not heated. Stays about 35 deg. F. during the coldest part of the winter up here. How much gas should I leave in my car? Should I start it every once in a while or is that unnecessary? Thanks for the advice.
I put fuel stabilizer in at the gas station, fill it up and drive it into the garage, onto four small pieces of carpet to keep the tires from flat spotting....cardboard will do too.
Disconnect the battery and then put it on trickle charge once a month for a day.
I put a coat of wax on mine prior to covering it up and leave a box of baking soda inside the car. I use a breathable cover for what it's worth....
