Cutting Fuel Line
Old Oct 23, 2004 | 05:23 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Cutting Fuel Line
I'm in the process of removing my carb and can't get the fuel line off.
I am going to attach a rubber fuel line to the hard line and have to cut it anyway.
So, I was wondering what the safest tool would be to acomplish this.
I've ruled out torch and flamethrower.
Thanks, Les
Old Oct 23, 2004 | 05:28 PM
Twin_Turbo's Avatar
Twin_Turbo
Can you get around the tubing or not? If you can use a tubing cutter, don't know what it's called exactly but it looks like this:
Old Oct 23, 2004 | 05:36 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
They make a teenie tiny pipe cutter too. It's good for a 3/8" line. That's what I used.
Otherwise I guess you can use a hacksaw if you have the clearance. If you feel real brave, a cut-off wheel.
Old Oct 23, 2004 | 08:34 PM
wills670's Avatar
wills670
if their is a garage you can borrow a small tubing cutter that is what i would do. most mechanics have the very small tubeing cutter they would probaly let you borrow one if you ask. or go to a hardware store and buy one they are not that expensive. if you cut with a hack saw you need to get the medal shaveings out of the line before you reattach line.
Old Oct 24, 2004 | 02:32 AM
AGVI's Avatar
AGVI
thanks!!!
Old Oct 24, 2004 | 03:29 AM
ewalker302's Avatar
ewalker302
Take a hacksaw blade, and wrap 1/3 of it w/electrical or duct tape for a handle, then saw away.
Old Oct 24, 2004 | 09:49 AM
jcswm's Avatar
jcswm
Cheap, Fast and easy
Old Oct 24, 2004 | 09:50 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
That's the one.
Old Oct 24, 2004 | 10:07 AM
stpman's Avatar
stpman
Originally Posted by Jughead
That's the one.
and they only cost a few bucks
Steve
To Cutting Fuel Line
