Dyno vid, my 78
Old Oct 23, 2004 | 09:09 PM
Shark Racer's Avatar
Shark Racer
Default Dyno vid, my 78
http://students.engr.scu.edu/~sbeeby/dyno_78.wmv
Car made 241 rwhp, 283 rwtq. Not quite what I was hoping for. A/F dropped to about 12:1 at 3800 rpm and stayed low all the way up to 6200 rpm.
I can't believe they ran the engine that high. Holy crap.
Where to go from here...?
-Steve
Old Oct 23, 2004 | 09:12 PM
1970-Bronze's Avatar
1970-Bronze
What's your current configuration?
Old Oct 23, 2004 | 09:14 PM
Shark Racer
8.5-ish-:1 compression
Crane 272 (216/216, 110 LSA .454"/.454")
AFR 195 heads
Edelbrock Performer EGR #3701
Q-jet #17058228
TH700R4 transmission
Old Oct 23, 2004 | 09:21 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Thanks for posting results. cardo0
Old Oct 23, 2004 | 10:00 PM
45ACP's Avatar
45ACP
Get that a/f ratio adjusted right. There is more power to be had!
Old Oct 23, 2004 | 10:39 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
why do you suppose the torque was so low? the HP seems respectable.... especially if you need to adjust it some . i'm just surprised at the torque #s????? and i bet it screams with that 700r4 in it.
Old Oct 23, 2004 | 11:07 PM
Shark Racer
I'm not sure. The A/F ratio didn't get really rich until about 4300 rpm, where it dipped down to 12:1. Wonder if the intake just shuts down at that point.
Maybe I should find someone to beef up an EGR performer...
-Steve
Old Oct 23, 2004 | 11:11 PM
bobs77vet's Avatar
bobs77vet
how do you know your timing is right? especially the vacuum advance portion? could you be hitting a "timing issue" at that RPM also?
Old Oct 23, 2004 | 11:13 PM
Shark Racer
Vac advance should be shut off on the dyno, no? I thought you get 0 vac advance at WOT. Timing is a good thing to play with though... I'll think about it. That could very well be why the torque is so low.
-Steve
Old Oct 23, 2004 | 11:20 PM
79VetteMike's Avatar
79VetteMike
hey dude, i'd completely expect substantially higher numbers. how many pulls did you get and did you do any tuning. it's great that you posted the results. i think you have alot left in the tuning......
Old Oct 23, 2004 | 11:40 PM
Shark Racer
3 pulls, and they were consistent as hell. I mean, literally, you can barely see the three lines on the graph.
I had the carb scoped out by a local place. I really need to play with timing and jetting methinks.
-Steve
Old Oct 23, 2004 | 11:41 PM
bobs77vet's Avatar
bobs77vet
why do they disconnect the vacuum advance while running a dyno test?
Old Oct 23, 2004 | 11:54 PM
lostpatrolman's Avatar
lostpatrolman
vacuum advance doesnt change anything at WOT like Pacin said. At WOT there is no vacuum so the advance unit will not advance timing any. Pacin, what rpm were your peak hp and tq at? How high did they run the engine on the dyno?
Old Oct 24, 2004 | 12:00 AM
Shark Racer
Peak hp ~5200 rpm.
Peak tq ~3800 rpm.
-Steve
Old Oct 24, 2004 | 07:51 AM
bobs77vet's Avatar
bobs77vet
-Steve
sorry about my poorly written/constructed post, what i was thinking but did not convey was what if " your timing is way off and the vacuum advance is luring you into thinking everything is ok at the normal rpm range?"
Old Oct 24, 2004 | 09:50 AM
1970-Bronze
I'm thinking you need to address the exhaust.......
Old Oct 24, 2004 | 11:21 AM
1970-Bronze
I checked your profile and see you already have the exhaust taken care of....
You may want to connect a pressure gauge to the exhaust just to verify it's performing. X or H pipe...
You could look at adding a carb spacer if there's hood clearence....
To Dyno vid, my 78
Old Oct 24, 2004 | 11:37 AM
SG4206's Avatar
SG4206
I would pursue leaning the jetting if the density altititude was 2000 ft. or more. It could be worth 10-15 hp. Normally around 13:1 AF gives best power.
You are correct, play with total timing; you could be surprised.
Old Oct 24, 2004 | 12:02 PM
Chuck Harmon's Avatar
Chuck Harmon
Steve,
Considering that a factory L82 would only have made 180rwhp, perhaps less because of an automatic, 241 is very respectable. Especially considering that you are still only running a little more than 8:1 compression. Remember that most guys claiming high hp numbers are usually "out to lunch".
You are even making significantly more than a 72 LT1 which was/is a very potent motor. When you get the a/f sorted out you can probalby expect about another 10hp or so, but you still made some very good numbers! Your 0-60 numbers are very good.
Chuck
Old Oct 24, 2004 | 12:08 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Great numbers considering the mild setup
