Electric fan install
Old Oct 24, 2004 | 10:32 AM
foundvettelifeisgood's Avatar
Default Electric fan install
I'm about to install...any tips regarding location of the relay, wiring to the fuse panel, etc. Thanks.
Old Oct 24, 2004 | 12:01 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
just recently last two weeks or so another forum member had alot of issues with his wiring on his fan and he got lot of good advice from people. if you search the forum and can find this post it will help you out.
Old Oct 24, 2004 | 12:19 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
http://forums.corvetteforum.com/show...7&page=2&pp=20
Halfway down page 2, I learned my lesson. the two yellows & 30amp fuses connect to the big (+) terminal on the starter.
I mounted my relays on the passenger side fender.
Old Oct 24, 2004 | 12:22 PM
bobs77vet's Avatar
bobs77vet
thanks, thats the post i was thinking of.
Old Oct 24, 2004 | 12:45 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Len,
I must have missed one of your previous posts. Did this change solve your misfire?
Foundvettelifeisgood,
Congrats! You'll love the electric fans.
Old Oct 24, 2004 | 12:52 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
For some reason the way I had the fans wired caused too much of a load on the ignition. That caused the engine to either die completely or start sputtering.
Note that this was one of the very first posts about my sputtering....I've had a few.
The last was solved by switching out carbs to a bigger, new Holley.
I now have a slight stumble right after shifting into 2nd & 3rd. Tach will read about 2000 after I shift up. I talked to a "car" guy yesterday who has a "Motion" clone and he said it might just be the cam not coming alive till after 2500. Which could be true.
Old Oct 26, 2004 | 03:21 AM
glen242's Avatar
glen242
Jay:
Meant to call you Monday, but I got sidetracked. Did you notice the setup on mine? Will try to give you a call on Tuesday, or you can call me.
Larry
Old Nov 14, 2004 | 09:51 PM
Default Thanks for the help...
I put the relay behind the dash,
Then carried the ignition lead to the fuse box, the battery lead to the starter and the temp sensor lead to the passenger side head. When I pulled the passenger side header to get a clear working area for the starter, I noticed a plug in the head between cylinders 6 and 8. So I pulled it and put the temp sensor there. This pic is of the plug before I pulled it and put the sensor in.
Old Nov 14, 2004 | 10:12 PM
R. Bruno's Avatar
R. Bruno
I put the relays on the front fender well. I also bought a junction box from madelectric.com and wired it in after the alternator as was suggested by Gary at Mad Electric using soldering and correct terminals. I have the junction box mounted on the drvier's side firewall. Finally I used flexible conduit to hide all the wire. Call Gary at Mad Electric, tell hm what you are doing and he will send you everything you need and advise you. This was the best $40 I have spent on the car.
Old Nov 14, 2004 | 10:47 PM
CA-Legal-Vette
Let us know how the instalation goes. I think that a lot of members are interested or consdering doing this. Only down side seems to be the cost.
Old Nov 14, 2004 | 11:07 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
L88 Hood, new fans.....I love this time of year, mod season.
Be sure to post some pics of your new fans.
Old Nov 14, 2004 | 11:52 PM
DMONSVETTE's Avatar
DMONSVETTE
Wow, looks like alot of really good advice and ideas show here.
I am also thinking about going from a flex fan to electric and
this should help. Good job guys!
Old Nov 15, 2004 | 09:52 AM
CGGorman's Avatar
CGGorman
I ran a second line directly from the battery using burial-grade 12-2 stranded cable. It runs parallel to the positive battery cable through the trans tunnel and comes up near the wiper door actuator. It allows easy under-hood access to power. I've got the MSD and Spals tapped into it.
To Electric fan install
