Gulstrand rear toe adjusters...
Old Oct 25, 2004 | 01:02 AM
lostpatrolman's Avatar
lostpatrolman
Default Gulstrand rear toe adjusters...
This seems to be something that could be very useful. Anyone have one or heard of them and how they work? Anyone have pics of them installed? I cant figure out how they would get installed.
http://www.guldstrand.com/toe.htm
Same thing with these, anyoen have any experience with them? Are they suitable for a daily driver?
http://www.guldstrand.com/joint.htm
Old Oct 25, 2004 | 07:58 AM
flynhi's Avatar
flynhi
A couple of years ago, I went to Guldstrand's shop and visited with him for about 30 minutes (A real gentleman).
We discussed all of his mods for C3s and which ones made sense for street/autocross use. He stated that the ones you are mentioning were really designed for racing and that it was necessary to lift the body off the frame to get access to install and adjust.
Not worth it, IMHO.
Old Oct 25, 2004 | 09:17 AM
SG4206's Avatar
SG4206
flynhi is correct -
We are installing a set in a '68 Vintage Racer with the body off. If there was a way to install this with the body on ; I would have this on all my C2s & C3s.
Old Oct 25, 2004 | 12:16 PM
lostpatrolman
So are the toe adjusters something you would set and leave alone until next time you realign the rear, or is it something that constantly needs adjusting? How much clearance from the body is needed, a few inches? If thats the case, it doesnt seem too bad. I could use an excuse to run new gas and brake lines. Anyone have any pics of these installed? Id love to see how they hook up.
Old Oct 25, 2004 | 12:28 PM
Twin_Turbo's Avatar
Twin_Turbo
Maybe this would provide the amount of space needed?
Here the section to which the body mount cover screws is removed. If you would make that whole section removable it might do the trick
Old Oct 25, 2004 | 12:38 PM
gkull's Avatar
gkull
Normally rear toe is set by using quality stainless steel washer shims on the front of the rear trailing arms. Once you set them and sinch everything down your toe shouldn't change for many years like 10+ if you don't ever hit anything.
So these adjustables might be fun to try a few different setting and then just leave it alone.
GM chose to build our vettes with lack of skilled drivers in mind. So they set rear toe to something like 1/8th inch toe in. Which gives self aligning to the rear end. So it will self correct to going straight even if you throw the rear end into a slide. It's the same thing with the front tires. Then set in a toe value which will keep the car going striaght with little or no input by the driver.
So a lapping car or for performance use you set the front and rear toe to "ZERO"
Old Oct 25, 2004 | 12:47 PM
lostpatrolman
So will the toe adjusters and solid bushings eliminate toe change when the car is autocrossing or anything, or is it all just to help adjust toe quicker?
Old Oct 25, 2004 | 12:49 PM
SG4206's Avatar
SG4206
They shouldn't need consant adjusting ; these give you the ability to change toe easliy and record change for handling benefits.
Old Oct 25, 2004 | 01:04 PM
Twin_Turbo's Avatar
Twin_Turbo
No, the toe change is because of the arc over which the suspension travels, with 1 hinging point you will always have a toe change, it's like a pendulum. The only way to completely emliminate it is to have a sectioned rear trailing arm like the C4 has.
Old Oct 25, 2004 | 01:05 PM
gkull's Avatar
gkull
LostPatrolman - SG4206 said it correctly. It is very time consuming to change out the washer shims.
This is what I said: Normally rear toe is set by using quality stainless steel washer shims on the front of the rear trailing arms. Once you set them and sinch everything down your toe shouldn't change for many years like 10+ if you don't ever hit anything.
Old Oct 25, 2004 | 01:23 PM
lostpatrolman
yeah, when i first saw them, i didnt realize they replaced the shims. I thought they were somehow used to help stop toe change.
Old Oct 25, 2004 | 02:32 PM
redvetracr's Avatar
redvetracr
George.....TOE IN!! ALWAYS!!
...redvetracr
Old Oct 25, 2004 | 03:49 PM
norvalwilhelm's Avatar
norvalwilhelm
...redvetracr
This is still debateable. With the new negative camber settings toe OUT is used also. Toe in was originally for positive camber.
As for toe adjustments the 6 link allows quick and easy toe changes for testing. For camber change you adjust one rod, for toe both strut rods equally.
Old Oct 26, 2004 | 04:37 PM
wills670's Avatar
wills670
lostpatrolman, pics. sent
Old Oct 26, 2004 | 04:43 PM
lostpatrolman
thanks
Old Oct 27, 2004 | 12:29 AM
Solid LT1's Avatar
Solid LT1
...redvetracr
I run 1/16" per side, my car was downright undriveable with "zero toe" when I tried it at the autocross course. I know of several top crewcheifs of IMSA/Trans-Am era Vettes and they all told me to go to 1/8" total and possibly up to 1/4" total for stability under acceleration out of the corners. Here is a quote from one: "the most viscious Vette I ever drove that almost killed me was one that was bordeline on rear toe-out, I would never even consider using anything approaching toe-out on a high horsepower/rear wheel drive car EVER!" (he tested Greg Pickett's 1100+HP twin turbo IMSA Vette during that era.)
To Gulstrand rear toe adjusters...
