HEI and shift light
Old Oct 25, 2004 | 09:03 AM
TTop Tony's Avatar
TTop Tony
Default HEI and shift light
Anybody hook up a shift light to 75+ car with HEI? Where is the negative coil? I see a B+ and a C- (I might have those backwards). Is the C- it? As always any help is appreciated?
Old Oct 25, 2004 | 03:53 PM
TTop Tony's Avatar
TTop Tony
I'll post in the dragrace forum too and see if anyone there is using a shight light with an HEI distributor.
Old Oct 25, 2004 | 08:02 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
On HEI you just hook it up to the tach terminal.
Old Oct 25, 2004 | 08:34 PM
jpatrick636's Avatar
jpatrick636
Right to the tach terminal.
Old Oct 25, 2004 | 10:44 PM
oregonsharkman's Avatar
oregonsharkman
4-wires right??? 1 to tach terminal on the hei, 1 to ground-----pick a block grd of your choice, 1 to light----just tap into an existing instrument light wire, and 1 to pwr---use the center of your fusebox...... should have and accessory terminal or two. I just put an autometer cobalt tach w/ shift light in my 76--------real straightforward.....
Old Oct 25, 2004 | 10:47 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
If you also run a MSD box - you'll have to connect the shift light to the msd box..
Old Oct 26, 2004 | 08:06 AM
TTop Tony's Avatar
TTop Tony
Thanks guys I'll just run it to the tach wire. It didn't mention anything like that in the instructions so I was a bit confused.
oregonsharkman hardest part of owning a corvette and doing electrical work to me is finding a ground
No I don't run an MSD box I've always wanted to but I've always heard they don't do much good when you have HEI.
To HEI and shift light
