One tooth off? Should I worry?
Old Oct 26, 2004 | 08:48 AM
Ace77's Avatar
Ace77
Default One tooth off? Should I worry?
Ok, put on the timing chain and rockers ( thanks Motorhead - now my valve covers don't fit ).
But I can't seem to get the timing dot straight up at 12 o'clock.
The balancer is pointing right at 0 on the cover. Now I realize the cover may be off a bit, but I think what's probably doing it is that I banged the crank gear on WRONG SIDE IN (no dot on the outside). Because of where the keyway is in relation to the teeth, I don't think I ever will get the dot to line up, one tooth over to the right will be right of center. Should I bother pulling the crank gear or will this work itself out at the distributor? I think I will have to pull it...valve timing will be off the timing of the pistons, ignition is something else all together...damn.
Old Oct 26, 2004 | 09:20 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
The dots on the cam and crank gears should be together not the cam gear dot at 12 oclock....pull the crank gear and turn it around and put the gears dot to dot! You almost caused yourself a LOT of extra work
Old Oct 26, 2004 | 11:21 AM
stingr69's Avatar
stingr69
Pull the crank gear off and flip it over. You can get a free loaner gear puller for that from several places such as Pep Boys or Autozone.
-Mark.
Old Oct 26, 2004 | 11:46 AM
Ace77's Avatar
Ace77
I still have a puller from when I tore it apart.
I'm not too concerned specifically about the dots. If the keyway and dot are both exactly at a tooth of the gear, it doesn't really matter. The dot is on the backside, about 6 teeth away, but things would still line up.
Mind you, now that I think about it, when I put the old gear on the crank too, I think the teeth didn't line up (it was probably on the "right" way), and they HAVE to be identical, so it must mean the keyway is NOT at a tooth.
So, it's coming off tonight.
Old Oct 26, 2004 | 12:19 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Those roller rockers sure do look purdy
I have the matching polished aluminum GM Emblem tall valve covers for sale too, gone too far to cheap out now
Old Oct 26, 2004 | 03:09 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i'm not following what you're saying about being off one tooth and since the other is also off so it doesn't matter.... what we are saying is that (in normal rebuild) the crank sprocket dot should be at 12:00 and the cam gear sprocket should be at 6:00. so that when you look at the sprockets one dot is right above the other...
Old Oct 26, 2004 | 03:30 PM
mvftw's Avatar
mvftw
I just did a Cloyes True Double Roller and the marks should be 12 & 6 but you should be firing on #6 that way...
Old Oct 26, 2004 | 03:39 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
You should be...I don't care what else is involved, if the dots are'nt together on the gear set your valve timing is out to lunch
Old Oct 26, 2004 | 04:13 PM
Larry B.'s Avatar
Larry B.
There are two problems with leaving the crank gear where it is. #1... the dot puts the engine at TDC so dot is 6 teeth from the keyway on backwards then it would be 6 teeth off in the other direction if you just turned it over. Also there most likely is no radius on the gear where it butts up to the crank nose so it may break. Now the cam gear puts the CAM in time with the crankshaft. moving the distributor only adjust spark timing... Not cam timing. So if the cam and crank aren't correct then moving the distributor will not compensate for any error at in the cam/crank relationship.. Sounds more complicated than it really is.
Old Oct 26, 2004 | 05:45 PM
Marv's Avatar
Marv
Default timing set
The cam gear can only go on in one position because of the dowel locator. The crank gear is located with the woodruff key and can only be advanced and retarded with appropriate timing keyways. If you don't pull that gear and put it on correctly you may not be able to get your damper pushed on the crank snout far enough. That can/will cause pulley and belt alignment problems later. I agree-dots together at 12 and 6 no matter what else. Good luck.
Marv-
Old Oct 26, 2004 | 11:52 PM
Ace77's Avatar
Ace77
Pulled it off - wasn't so tough the second time around.
Flipped it over and lined it up - perfect now.
Also installed the timing cover, balancer, pulley, and intake.
Having read about it so many times, it's nice to finally get it moving along.
Thanks for the pushes...
To One tooth off? Should I worry?
