brake lights gone out!
Old Oct 26, 2004 | 05:44 PM
michaels1fst69's Avatar
michaels1fst69
Cruising
Default brake lights gone out!
I just replaced all the bulbs with new ones, and my brake lights work until I hit the brakes then one lights up more for the brakes but one goes out completely, I also put reverse lights in but they do not work at all, the car has a hurst shifter in it so did someone not hook something back up at one time?
Old Oct 26, 2004 | 05:51 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Probably it's not the brake light switch ($2.95 at AutoZone)....
pull the wires out after you removed the taillight covers and check if someone messed around with them, also compare the colors left/right...maybe one side is connected wrong...
