Split from "heads" what trucks had vortecs?
Old Oct 27, 2004 | 10:20 AM
Joebio's Avatar
Joebio
Default Split from "heads" what trucks had vortecs?
If I was to go to a boneyard to find a set of vortecs what vehicles would I be looking for? Did the factory ever install aluminum vortecs on any vehicles?
Old Oct 27, 2004 | 10:29 AM
TIMTEMEC's Avatar
TIMTEMEC
96-98 gm 5.7 v8 trucks. There cast iron heads.
Old Oct 27, 2004 | 10:31 AM
NHvette's Avatar
NHvette
Search for more info ... I recall that there are at least two
different castings. You want the later - improved - casting.
Old Oct 27, 2004 | 10:44 AM
Joebio's Avatar
Joebio
Sorry should have searched first. Seems the casting ending in 906 are the better heads, yes/no?
Old Oct 27, 2004 | 10:50 AM
79VetteMike's Avatar
79VetteMike
I have a set and an intake for sale. I thought I was working with a guy, but he never answers my emails.
Old Oct 27, 2004 | 11:00 AM
mooneyd's Avatar
mooneyd
My '96 Tahoe has them, but they are not alum.
flood's Avatar
flood
http://www.carcraft.com/techarticles/81998/
Here is an article on a build up with Vortec heads.
Old Oct 27, 2004 | 11:49 AM
The Dude's Avatar
The Dude
My '01, also. I don't know whether they're aluminum or iron off the top of my head, though.
Old Oct 27, 2004 | 12:08 PM
markdtn's Avatar
markdtn
Vortec Heads are not aluminum. They would be on 96-98 (and some 99 3/4 and 1 tons). Also Tahoes and Suburbans. I don't believe that any would be on an '01.
markdtn's Avatar
markdtn
Vortec Heads are not aluminum. They would be on 96-98 (and some 99 3/4 and 1 tons) trucks. Also Tahoes and Suburbans. I don't believe that any would be on an '01.
Old Oct 27, 2004 | 12:18 PM
Joebio's Avatar
Joebio
79vettemike you have a PM
Old Oct 27, 2004 | 12:27 PM
Uesu's Avatar
Uesu
One gear at a time
Veteran: Marine Corps
CI 8-9-10 Veteran
St. Jude Donor '07-'08-'09
There have been many Vortec posts in the performance forum of Team Chevelle. An engineer from GM Performance Parts occasionally posts there. According to him, there is no real differance between the 906 and 062 heads. HTH Wes
Old Oct 27, 2004 | 01:43 PM
79VetteMike
I must have missed an email or two from the person that wanted the heads because he contacted me. My mistake. The heads are not available because they are sold. Thanks
Old Oct 27, 2004 | 02:46 PM
The Dude's Avatar
The Dude
Interesting. I need to spend some more time under my DD's hood, I guess. I was assuming "Vortec 5300" = "Vortec heads."
Old Oct 27, 2004 | 04:04 PM
Uesu's Avatar
Uesu
One gear at a time
CI 8-9-10 Veteran
The '96-98 062 and 906 Vortec heads are cast iron. The later, aluminum "Vortec" heads are different and will not bolt to a small block Chevy engine. The later aluminum "Vortec" heads are based on the LS1 series of engines. HTH Wes
Old Oct 27, 2004 | 04:09 PM
7t5's Avatar
7t5
St. Jude Donor '14
The new Vortec motors are 4.8, 5.3, 5.7, and 6.0. These are gen 3 motors and will not interchange with any gen 1 parts. These are 1997(?) to present and go in most GM trucks and sport utes. Also Corvettes, GTO's and the f bodies (before the production ended). These all have aluminum heads except some early 6.0, which were iron.
The Vortec heads you refer to are in the previously mentioned trucks. I have no idea why GM called the gen 3 Vortecs the same name as the old style, but it confuses many people. Now when you retrofit that 5.3 into a vette, we would all like to hear about it! They make an aluminum version that is sure to be a good hot rod swap.
Old Oct 27, 2004 | 08:39 PM
The Dude's Avatar
The Dude
I don't think a 5.3 into a 'Vette would be the best swap out there unless it was into a C2 or C3 destined for cruising only. For the money I'd stick with LS-1 or an LS-6. More power = Cool.
The aluminum-blocked version Gen III SBC comes in the SSR, I believe, and I've seen them installed in MANY sand buggies. (And Viper V-10s and LS-1s and Northstars, too.)
To Split from "heads" what trucks had vortecs?
Old Oct 27, 2004 | 09:00 PM
comp's Avatar
comp
check in if it doesn't work
Old Oct 27, 2004 | 10:19 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
To clarify, they were available on the 96-99 C/K style trucks. In 99, both the C/K and the Silverado were available at dealerships. Both were sold as 99 models.
Old Oct 28, 2004 | 11:08 PM
7t5's Avatar
7t5
St. Jude Donor '14
I think the 5.3 would be a great swap. Thats close to a 327, Right? Let me tell you, with a few minor mods that motor would be a real screamer in a c3, and not to mention cheaper to come by than an LS6 or LS1. Also easier to supercharge a fuel injected mill, if you could find room under the hood.
You are right. They also come in the SSR. I thought about that last night after I posted. By the way, I work at one of the facilities where these are made. We currently only machine iron blocks, but assemble iron and aluminum. What a cool place it is to work!!
