Hey TH200R4 users...
Old Oct 27, 2004 | 05:17 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Hey TH200R4 users...
Does anybody here use a TH200R4 with a stock crossmember???
Is it possible?
Old Oct 27, 2004 | 06:33 PM
GrandSportC3
ttt
Old Oct 27, 2004 | 07:08 PM
redwingvette's Avatar
redwingvette
I do. Fit perfect using the stock crossmember for my TH400.
Trans install
Old Oct 27, 2004 | 07:13 PM
GrandSportC3
Trans install
Thanks!!
Old Oct 27, 2004 | 07:51 PM
page62's Avatar
page62
Yes. The '79 auto had the big, classic crossmember with 2 holes. It changed in '80, so the last 80-82 cars require a replacement crosmmember.
Old Oct 27, 2004 | 07:53 PM
Hershey's Avatar
Hershey
If you had a TH400, then the 200R-4 bolts up with no changes. I used the trans mount off of my TH400 and the linkage arm off of the TH400. The speed-o cable connects to the 200R-4, though you will find that it has to stretch an additional 3 inchs to reach. Change to TH350 yoke and hook up TV cable with new bracket and you're home free. Hershey
Old Oct 27, 2004 | 08:04 PM
GrandSportC3
I wonder if the manual transmission crossmember on my car will also work with the TH200R4... I know that I'll only be able to install/remove the tranny if the engine is out...(because of the fixed crossmember)...
Old Oct 27, 2004 | 08:55 PM
comp's Avatar
comp
that would suck you have your's there
Old Oct 27, 2004 | 09:00 PM
shoptek's Avatar
shoptek
Old Oct 27, 2004 | 11:45 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Trans install
But if another $180 won't hurt, the BowTie crossmember is a bit more areodynamic.
http://www.bowtieoverdrives.com/cata....php?ITEMID=62
Old Oct 28, 2004 | 12:00 AM
Contrail's Avatar
Contrail
So, what if you have a TH350? Same deal? Bolt right up?
Old Oct 28, 2004 | 12:30 AM
Schmucker's Avatar
Schmucker
Yep, remove the extension on the crossmember and it bolts right up. Not a bad idea to replace that big heavy pig crossmember with a lightweight tubular one though.
Old Oct 28, 2004 | 06:23 PM
GrandSportC3
Well - I'm sure that it's lighter too.. The only problem is that the install of such crossmember ain't cheap... I don't have any tools, equipment or skills to cut the original crossmember and install the new bolt on crossmember...
I'm sure that it's going to cost a couple 100 bucks to install that crossmember...
Old Oct 28, 2004 | 07:08 PM
shoptek's Avatar
shoptek
The only problem is that I don't have the skills.
You said it buddy Just kidding.
If the car is down here, I'm sure we could figger out a solution, especially with the brain of Mr. Wonderful!
Old Oct 28, 2004 | 08:31 PM
GrandSportC3
A brain won't cut a steel crossmember...
Old Oct 28, 2004 | 08:33 PM
Contrail's Avatar
Contrail
What extension? Gotta pic of it? I've got a line on a 2004R right now (gonna trade a 82 collector's edition drivers side top for it, unless one of you guys wants it...) so I need to start getting all my ducks in a row for the install.
Old Oct 28, 2004 | 08:41 PM
page62's Avatar
page62
The extension consists of all the bits that go forward from the crossmember to the TH350 mounting location. Does not apply to the TH400.
To Hey TH200R4 users...
