How much ground clearance
Old Oct 29, 2004 | 04:36 PM
Gordonm's Avatar
Gordonm
Default How much ground clearance
Looking at all the Vettes here on the forum some look lower than mine. I think mine could go down another 1/2 to 1 inch. Right now I have only 3 inches to the bottom of the blowshield. 3 1/2 to the bottom of the headers and in the back 4 inches to the exhaust pipes. How are you guys running lowered Vettes without tearing the under carraige out of the car. I bumped the bellhousing once on a speed bump and I was being careful There just does not seem to be a lot of clearance to lower the car.
Old Oct 29, 2004 | 05:10 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I've got 4 inches to my Mooso oil pan and 3.5 inches on the side exhaust at the front wheel opening. So far, I've only scraped the side exhaust pipe on the passenger side.
Old Oct 29, 2004 | 05:12 PM
PRNDL's Avatar
PRNDL
Gordon, you need an extra 1.5" if you are going to drive in New Jersey!
Old Oct 29, 2004 | 05:22 PM
Gordonm's Avatar
Gordonm
At least 1.5 inches. That is why I hesitate to lower the car.
Old Oct 30, 2004 | 08:59 AM
Gordonm's Avatar
Gordonm
Anyone else
Old Oct 31, 2004 | 10:37 PM
Solid LT1's Avatar
Solid LT1
I cut the bottom flange of my Lakewood scattershield off to gain ground clearance on my LT-1 Vette (if the clutch blows and pukes out the bottom, I don't care and none of the tech inspectors at the drag strip have seemed to care either!) My Hooker Super Comps are the lowest point of my LT-1 right now and showing signs of it too (a few scrapes and bends on the collector flanges.) My wife drove my car before I cut the bottom flange off of the scattershield and we hit a speed bump and ground to a QUICK! halt when the flange came into contact with the bump! You can use your stock oil pan as a guide for cutting the flange or just go parallel to the bottom of the engine block about 7.25" down from the oil pan rail. I also welded all the nuts to my block plate of the sheild and the tech guys really like the fact that I have all the bolts in place on my scatter shield.
Old Nov 1, 2004 | 01:15 AM
marky mark's Avatar
marky mark
On my '69 427 'vert with the Vette Brakes street slalom kit which did lower it a bit I have 3 &1/2" up to the Hooker Headers. Not as big a deal as I thought it might be. Just have to watch any speed bumps or dips in parking lots,etc. No problem on the road though.
regards, Mark
Old Nov 1, 2004 | 08:16 AM
PatsLs1vette's Avatar
PatsLs1vette
i havent measured yet,ill measure this after noon when im done wet sanding the car out and put the 17's back on.
Old Nov 1, 2004 | 11:08 AM
UKPaul's Avatar
UKPaul
Originally Posted by Gordonm
Anyone else
The lowest part of mine is where the exhaust pipe runs under the drivers floor pan. It's got 3" of clearance with nobody sitting in it. It does ground out. Mainly where 2 roads intersect on the crest of a hill so that there's a hump. The only other problem is a local road that has a series of dips & bumps (undulations). At certain speeds the suspension movement gets in sync with the road surface so that the car decks out on the humps. This isn't good. 1st time it happened there was an almighty loud clang & one heck of a bang right up through the drivers seat. I reckon stronger front springs should help, but I find that I'm constantly on the lookout for fierce humps/bumps in the road.
I avoid speed bumps wherever possible, even if it means taking the long way round. My daily driver decks out on some of the local humps (it's currently got a split exhaust pipe from a speed hump & I'm buggered if I'm going to pay for a new one just to do it again). The dd has far more clearance than the Vette, so I avoid them (instead I take a detour through residential areas, along with all the other traffic avoiding the humps - how the residents must love a barely muffled SBC rumbling by late at night).
Old Nov 1, 2004 | 03:01 PM
75 Hot One's Avatar
75 Hot One
I've got 2 1/2". Low spot is exhaust pipes where they pass under the rear spring. I try to avoid speed bumps and anything else laying on the road.
To How much ground clearance
