Wheel offset ? 15x8x+-?
Old Oct 29, 2004 | 11:19 PM
David Ey's Avatar
David Ey
Default Wheel offset ? 15x8x+-?
does anyone know the factory offset for stock alum. wheels? '78
I want to buy some temporary steel wheels to use while my aluminum ones are being chromed. ie: what other junkyard wheel fits?
Old Oct 29, 2004 | 11:22 PM
GDaina's Avatar
GDaina
4.75" offset...
Old Oct 29, 2004 | 11:25 PM
David Ey's Avatar
David Ey
OK, is that the same as a plus 3/4 inch offset?
Old Oct 29, 2004 | 11:32 PM
GDaina's Avatar
GDaina
Eh?
Tell ya what, just get some wheels from any 68 and up Corvette, guaranteed to fit.
Old Oct 30, 2004 | 09:54 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I have a set of 15X8 rally wheels (245-60 rear and 225-70 front) if you're interessted. Three tires are in good condition, all three are Dunlops, one front was obviously the spare tire at some point in time, different brand and shot...
Old Oct 30, 2004 | 10:17 AM
Summerfun's Avatar
Summerfun
Originally Posted by GDaina
4.75" offset...
Backspacing, you mean!
Offset is a completely different animal, David.
It has to do with the mounting surface of the wheel and its relation to the centerline.
Old Oct 30, 2004 | 10:36 AM
Summerfun's Avatar
Summerfun
Here is something to chew on:
Measuring Wheel Offset
To calculate offset you'll need the following measurements:
Wheel backspace
Wheel Width
Wheel Center line (outboard flange to inboard flange measurement / 2)
Subtract:
Wheel center line from Wheel backspace to get offset. If backspace is less than the wheel centerline the offset is negative
If backspace is greater than the wheel centerline the offset is positive
Old Oct 30, 2004 | 11:25 AM
GDaina's Avatar
GDaina
Yep, that's what I meant.....as I said before, get 7" or 8" wheels from any 68 and up and you won't be bothered with measurements....
Old Oct 31, 2004 | 09:29 PM
Solid LT1's Avatar
Solid LT1
Buy my "Pace Car" wheel set for $175 and have a matching extra set for your drag slicks! I can Email you photos if your interesed. They have a set of 275/50/15 Hoosier RS03 autocross tires on them (but 2 are "corded" and not really useable.) I am also giving you the correct lug nuts and center caps (lug nuts are about $3-4 each so there are $60 worth of lug nuts included!)
Old Oct 31, 2004 | 09:46 PM
David Ey's Avatar
David Ey
Thanks for your input guys.
Old Oct 31, 2004 | 10:49 PM
C8H18's Avatar
C8H18
4.75" offset...
1/2" Negative offset
To Wheel offset ? 15x8x+-?
