center console/armrest removal
Old Oct 30, 2004 | 01:38 PM
jlch's Avatar
jlch
Default center console/armrest removal
Trying to remove the console/armrest. You know the piece that goes around the e brake and holds the armrest and power window swithches. I removed the four screws from the sides but she won't budge. Is there something else holding it on? maybe in the back under the carpeting?
Old Oct 30, 2004 | 01:50 PM
Pedro'74's Avatar
Pedro'74
Lou,
There's another bolt in the rear, that can be reached by removing the storage box. One of those things that make you think... "what the hell were they thinking?!"
-Pedro
Old Oct 30, 2004 | 01:51 PM
jlch's Avatar
jlch
the storage box you are referring to is the center compatment I am guessing?
Thanks.
Old Oct 30, 2004 | 01:54 PM
Pedro'74's Avatar
Pedro'74
Actually I removed the passenger side box, as (at least on the 74) it is easier to remove (just pull it).
-Pedro
Old Oct 30, 2004 | 03:58 PM
Glassbowtie77's Avatar
Glassbowtie77
What year is the car? There are different set-ups on certain year cars.
Old Oct 30, 2004 | 04:22 PM
checklst's Avatar
checklst
They could have used a steel dowel pin and not bothered with the bolt, it is darn hard to get to!!!!!!!!!!!!!!!!
Old Oct 30, 2004 | 05:14 PM
Stoge's Avatar
Stoge
Old Oct 31, 2004 | 08:58 AM
carl a's Avatar
carl a
while your in there-(famous last words) do you have the light that goes on when you open the storage compartment? reason i ask is- while i was removing that bolt in the center compartment that holds on the brake console i noticed a wiring jack laying down there,, thats when i found out there is a light you can get (comes assembled with the switch and the bulb)- i used a unibit to get the hole the right size to accept the switch/light..
To center console/armrest removal
