MSD making noise?
Old Oct 30, 2004 | 03:00 PM
75 Stingray!'s Avatar
75 Stingray!
Default MSD making noise?
I just finished the install of a msd 6al, when I fired her up the box was making a buzzing noise is this normal?
My radio was off and the faceplate removed, the noise was coming from the box.
The car ran normally, I didn't notice any difference in power. I was not able to test much because it started to rain. Idle seemed to have dropped.
Old Oct 30, 2004 | 06:03 PM
jcswm's Avatar
jcswm
Mine buzzed when the supply voltage got too low
Make sure you've got a full 12v supply!!!
Old Oct 30, 2004 | 06:36 PM
75 Stingray!
I hooked up the positive to the starter where the thick battery cable hooks up, and the ground to the birdcage. I guess I’ll borrow my friend’s voltmeter and check it out.
Old Oct 30, 2004 | 10:20 PM
7Bob3's Avatar
7Bob3
Run the ground to the block.
To MSD making noise?
