Fan shroud flex?
Old Oct 31, 2004 | 07:42 AM
78pacer's Avatar
78pacer
Default Fan shroud flex?
My L-82 when revving in nuetral, makes the fan shroud flexdownward toward the fan. The darn thing doesn't hit, but I have never seen so much flex from a shroud on anything before. Is this normal?
Mike
Old Oct 31, 2004 | 11:55 AM
Retro78's Avatar
Retro78
I had a similar problem, until I realized that bubba had broken off the top and bottom bolt tabs. I believe your shroud in that year is bolted by two top bolts and two bottom, mine were missing completely including the tabs.
Old Nov 1, 2004 | 09:16 AM
78pacer's Avatar
78pacer
Thanks for the reply,
I'll check it out real good
Old Nov 1, 2004 | 09:21 AM
wcsinx's Avatar
wcsinx
Is the shroud actually flexing, or is the entire shroud moving? I suspect the latter (i.e. another vote for a mounting issue) because these shrouds are quite rigid.
To Fan shroud flex?
