Head Lights Rubbing
Old Nov 1, 2004 | 01:18 PM
JIM PORTER's Avatar
JIM PORTER
Default Head Lights Rubbing
I Have A 1975 Vette With A New Paint Job And My Headlights Are Rubbing The Paint When Opened They Look Like They Are Alligned Ok Is There An Adjustment To Stop Them From Rubbing
Old Nov 1, 2004 | 02:17 PM
72LS1Vette's Avatar
72LS1Vette
Check the headlight support bar (not sure if that is the correct term) to make sure it is bonded to the nose. The bond can break over time or from damage and result in the lights rubbing. I couldn't get the lights on my project car to open without hitting the rear lip of the opening and I later discovered that the bar had detached from the nose.
Rick B.
Old Nov 1, 2004 | 02:56 PM
jamesx0's Avatar
jamesx0
Is this a problem for the sides? If so, there are two collars on the pivot bar that adjust the side to side clearance. The collars are held in place with allen head set screws. One of mine came loose the other week and chipped a piece of fiberglass from the head light surrounds.
Old Nov 1, 2004 | 03:01 PM
JIM PORTER's Avatar
JIM PORTER
Default Rubbing In The Back
No It Is In The Back On Both Sides
Old Nov 1, 2004 | 05:26 PM
Star79's Avatar
Star79
Here's a thread from a while back with some pretty good intructions for adjusting your lights:
http://forums.corvetteforum.com/showthread.php?t=864403
Make sure the bar is attached first (as noted above) or you'll have to deal with that before you can start adjusting anything.
Good luck!
Old Nov 1, 2004 | 06:22 PM
Edzred72's Avatar
Edzred72
Good luck!
Had the same problem after paint...it was the support. I used 3-M fast setting urathane calk and C-clamps to bond it. It's used for sealing windshields, sets in 24hrs and bonds metal to fiberglass real well. Headlights are near perfect now.
Eddie
To Head Lights Rubbing
