Center Console Install Results
Old Nov 2, 2004 | 07:51 AM
Karfever's Avatar
Karfever
Default Center Console Install Results
I just finished installing a reproduction Center console in my 69. The manufacturer/supplier was Corvette Central, bought through Wilcox. I had heard alot about poor fit and other issues with these reporduction interior parts, but in my case the fit/finish was very good, almost as good as the original part. I also notice some extra reinforcement at various points in the substructure.
I hope this helps those of you who are unsure which way to go with these type of parts.
Old Nov 2, 2004 | 08:00 AM
comp's Avatar
comp
need pic's
Old Nov 2, 2004 | 09:03 AM
79ls1's Avatar
79ls1
Yes, pic's please
Old Nov 2, 2004 | 01:34 PM
Thumper76's Avatar
Thumper76
The Corvette Central interior pieces I've bought don't seem to fit very well. The center console shift plate opening was a good 1/2" too narrow for the shift plate to fit. The windshield surround pieces fit terrible too. I also got mine from Wilcox. Maybe I got factory seconds, I don't know. Glad to hear that everything worked out well for you.
Old Nov 2, 2004 | 07:20 PM
Karfever's Avatar
Karfever
I will try to post photos tonite...between election results!
Old Nov 2, 2004 | 07:53 PM
Karfever's Avatar
Karfever
I cant get the process right to post photos on a response. If someone can do this, this is the lionk to the photo!
http://forums.corvetteforum.com/phot...4963&password=
Old Nov 2, 2004 | 08:18 PM
redwingvette's Avatar
redwingvette
"This category does not contain any images."
is all I got
Old Nov 2, 2004 | 08:57 PM
Karfever's Avatar
Karfever
When I went back to it, it said "image under review' I will email to anyone who can post it!
Old Nov 3, 2004 | 03:48 AM
standup's Avatar
standup
Originally Posted by Thumper76
......The center console shift plate opening was a good 1/2" too narrow for the shift plate to fit........
.....you have to heat this up with a blow dryer to soften the vinyl and foam.......once it's softened, it will fit perfectly and harden around the shift plate.....
Old Nov 3, 2004 | 07:14 AM
Karfever's Avatar
Karfever
That is what I did, I used a heat gun and SLOWLY heated the console while I tightened the console plate down. After it cooled, the fit is perfect as the console formed its'self around the plate.
Still cant get the DA** pictures to post.
Old Nov 3, 2004 | 08:14 AM
Edzred72's Avatar
Edzred72
The interior restorers favorite tool!!! Both of my Corvette America door panels needed the heat gun treatment also.
Eddie
Old Nov 4, 2004 | 06:42 PM
Karfever's Avatar
Karfever
[IMG]http://[/IMG]forums.corvetteforum.com/photopost/showphoto.php?photo=22591
Old Nov 5, 2004 | 08:00 AM
vettfixr's Avatar
vettfixr
I'll just jump in here with a side note. When I replaced the parking brake console on my 74 I got the replacement console that had the storage compartment in the rear. It seemed like a good idea at the time and is very useful for holding things like sunglasses, garage door openers, cigs, etc. The only problem is that because it's higher than the original console in the rear your elbow tends to hit the cover on top when you do a 1 - 2 or a 3 - 4 shift. I guess if you had an automatic it wouldn't matter but it's a little annoying with a 4 speed. I usually drive with the cover off and then replace it when parked. Just a heads up to anyone considering this mod.
Old Nov 5, 2004 | 08:07 AM
ICEMAN59's Avatar
ICEMAN59
I got the pic from the link, nice interior, looks great!
Old Nov 5, 2004 | 08:11 AM
FormerPacifist's Avatar
FormerPacifist
here it is
Old Nov 5, 2004 | 06:49 PM
majic1984's Avatar
majic1984
Very nice!! Is that Plush or 80/20 loop carpet?
Old Nov 5, 2004 | 06:52 PM
olouieo's Avatar
olouieo
looks great!
To Center Console Install Results
