New Intake Purchase
Old Nov 2, 2004 | 11:20 AM
wadey's Avatar
wadey
Default New Intake Purchase
Getting close to purchasing a new intake and am looking at the performer rpm Q- jet and the airgap as possible canditates. Would love some info on these two, their pros and cons and how they compare.
thanx wade
Old Nov 2, 2004 | 05:54 PM
wadey's Avatar
wadey
ttt
Old Nov 2, 2004 | 05:57 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
If im correct, you will have problems useing the
air gap rpm, as for the intake is kinda tall.
what year model you working on, a little more info
would help a great deal
Old Nov 2, 2004 | 08:03 PM
wadey's Avatar
wadey
Sorry for lack of info,i have a '76 vette with the medium rise hood. Also i am running a drop base air cleaner with a '70 LT1 high rise al. intake.This intake is quite high so i should be able to handle one of the two options memtioned. thanx wade
Old Nov 2, 2004 | 09:17 PM
i885744's Avatar
i885744
i'm not an expert on fittment, but it sounds like either one of those combo's will work.
Numbers wise, the rpm airgap makes the most power of any dual plane aftermarket manifold.
Old Nov 2, 2004 | 10:21 PM
DMONSVETTE's Avatar
DMONSVETTE
See my webpage for Performer EPS with Permastar coating.
Old Nov 3, 2004 | 09:10 AM
Ganey's Avatar
Ganey
The SBC RPM intakes are very similiar & same heights. Properly set up you can expect similiar performance. For many years, performance enthusiasts have run blocked heat risers & added a lifter valley baffle for a cooler intake. The divider is sometimes cut down for hotter setups.
Trying an open spacer can help determine if you want a cut divider.
More info. on your setup is needed- C.I., trans. (converter) gears, etc.
To New Intake Purchase
