1981 Carburetor question
There is a secondary lockout lever going from the choke mechanism to the secondary throttle rod on the passenger side. Make sure it's not preventing the secondaries from opening when the engine is warm.
Also, consider buying a copy of the book Rochester Carburetors by Doug Roe. It covers all the QJets, including the computer controlled models like yours. You can find it on Amazon.
will be doing that this winter.
If there isn't a mark then they're not opening & you need to find out why. Doug Roe's book is good, but rather than shelling out on a new carb & dist, spend out on the shop manual for an '81. It's not cheap, but there's very good sections in it on both the carb & the computer system, which are worth the cost of the manual on their own.I never noticed any extra induction roar on mine, even though the secondaries are opening. Maybe the stock air filter housing does a good job of silencing it (noise regulations)? Or maybe it hasn't got any chance of being heard over the din coming out the back?
Good luck.
edit: typed the above in a hurry (it's not very good!). Best bet is to check out the archives. The '81 secondaries are just like earlier Q-jets from the point of view of what you're looking at & there's been a few posts on secondaries not opening in the past. They generally get better replies than what I typed above. If you can't find anything, just create a new post asking how to check for the secondaries opening, but don't mention '81 (a lot of people skip posts regarding '81's & their "complicated" computer control, even though they probably know the answer & probably frequently sort out problems with their PC's - which are far more complicated than the basic computer in the '81)!!!!
You can't really hear the secondaries opening with the stock air cleaner system. It was easy to hear on the mid-70's Vettes because of the cowl induction hood, which by all reports makes a goodly amount of noise. By the late-70's, however, the system was changed to a cold air intake over the radiator...which pretty well muffles any secondary "whoosh" you might have otherwise heard.
