Help!..dimmer switch actuater
Old Nov 6, 2004 | 11:07 AM
DonBama's Avatar
DonBama
Default Help!..dimmer switch actuater
I recently replaced my cruise control switch on my 81, in doing this i removed the access cover on the left side of the steering column. when i did this the plastic actuater for the headlight dimmer swith fell out, has anyone got any suggestions on how to get this piece back on with the cover with out taking the steering column apart?....thks Don
Old Nov 6, 2004 | 11:50 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i can't help with this one and in fact i was so disillusioned with trying to replace my dimmer switch i relocated it to the floor with a foot switch.....it actually was quite simple and all i had to do was cut off the "retaining" tab onthe coupling connector.....
Old Nov 6, 2004 | 04:56 PM
Jim Shea's Avatar
Jim Shea
Assemble the plastic dimmer rod actuator to the end cap using some heavy grease. The actuator is guided between the end cap and the metal housing and is retained during assembly by the grease on the little square post inside the cap. Without the grease, the actuator is very difficult to hold in place while reassembling the column because the wire rod isn’t exactly tightly fixed in position.
To Help!..dimmer switch actuater
