posi-trac id ?
Old Nov 6, 2004 | 07:48 PM
rbeckert's Avatar
rbeckert
4th Gear
Default posi-trac id ?
I have a 69 T-Top and a 63 conv. I know the 63 is not posi-traction. I am trying to find out how I can determine if the 69 is posi or not. Anybody out there know an easy way to tell ?
Old Nov 6, 2004 | 08:05 PM
Larry B.'s Avatar
Larry B.
Jack up both sides. (both rear wheels off ground). spin one wheel by hand. If the other wheel turns the same direction you have a posi unit. If not, the opposite wheel will turn the opposite direction.
Old Nov 6, 2004 | 11:41 PM
smoothsailing's Avatar
smoothsailing
Didn't know they sold Vettes that weren,t posi?
Old Nov 7, 2004 | 03:55 AM
comp's Avatar
comp
that doesn't allways work
Old Nov 7, 2004 | 06:10 AM
Larry B.'s Avatar
Larry B.
I have never seen a posi that turned the opposite direction. I've never seen a non-posi that turned the same direction so I think it works. How could it not work that way? BTW... In 69 positraction was still an potion but required with certain engine/trans options an gear ratios. I believe posi became standard in 1970.
Old Nov 8, 2004 | 06:07 AM
ewalker302's Avatar
ewalker302
My 69 has a big warning sticker on the underside of one of the storage compartment lids, I think the jack storage behind the pass seat. It says something about positraction equipped in big red letters.
Old Nov 8, 2004 | 07:53 AM
LFZ's Avatar
LFZ
DO you know what engine/trans combo. I have a 69 with 350/300, 4speed..and it has the red posi label on the differential. But for some reason, it doesn't feel like positraction...i'll have to do the tire turning trick i guess.
Old Nov 8, 2004 | 08:58 AM
1971Coupe's Avatar
1971Coupe
lay some rubber
Old Nov 9, 2004 | 03:19 PM
mattradaz's Avatar
mattradaz
5th Gear
Default Posi or not Posi...that is the question!
Have you checked the bottom of the differential carrier housing just in front of the rear end cover for the code?
Should be something like "AL-04 09 W". If your rear end is posi it will have an "E" below it.
To posi-trac id ?
