Help! to dissolve rust off parts?
Old Nov 7, 2004 | 12:26 AM
darrentpi's Avatar
darrentpi
Default Help! to dissolve rust off parts?
I am in search of some sort of over the counter acid or solvent that best can dissolve rust off parts, I have engine brackets, and nuts and bolts, that I want to clean, back to that dichromate, or shiny new look, but I don't want to have to take my parts to a specialty place to do this.
Does anyone know of what works really well!
Thanks,
Darren
Old Nov 7, 2004 | 12:37 AM
omarsmgff's Avatar
omarsmgff
i think there was a post about using vinegar to dissolve rust off they had pics and looked pretty good, try doing a search!
Old Nov 7, 2004 | 01:12 AM
randy814u's Avatar
randy814u
I have used the vinegar a couple times now, works great and is cheap.
randy
Old Nov 7, 2004 | 02:01 AM
The Dude's Avatar
The Dude
Vinegar.
Old Nov 7, 2004 | 03:54 AM
comp's Avatar
comp
going to be doing a bunch myself
Old Nov 7, 2004 | 09:09 AM
tshort's Avatar
tshort
CI 7-8 Veteran
I tried vinegar a few weeks ago and here is my tip. Make sure the whole part is submersed in vinegar if you're going to leave it in there for a while; all night for example. I soaked some valve stems in vinegar and the tips where sticking out. The tips where fine before but after this they had some rust on them and even after getting the rust off, that area was effected. It lost all of the polish. Weird????
Old Nov 7, 2004 | 09:12 AM
Twin_Turbo's Avatar
Twin_Turbo
Vinegar works for light rust, parts will rust very quickly afterwards though.
Isn't there someone you know or a business nearby that has a blasting cabinet?
Old Nov 7, 2004 | 01:03 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
TT is correct on both counts, though if you don't have access to all the toys that TT has at his disposal, you can also use muriatic acid, which is available at pool supplies or Home Depot. You MUST TAKE PRECAUTIONS when using this though. Eye protection and gloves at a bare minimum. The fumes can be an issue as well. You don't want to leave parts in too long either. I used to use this a fair bit when working with farm equipment and it will remove rust quickly and vigorously. Washing the parts down with water and baking soda afterwards is a good idea as well.
Old Nov 7, 2004 | 01:27 PM
comp's Avatar
comp
i'm doing bolt's etc. NOT engine part's
Old Nov 7, 2004 | 08:18 PM
LemansBlue68's Avatar
LemansBlue68
Captain Lee's "Rust Away"! Can be bought through:
http://www.halonmarketing.com
I bought mine through a dealer at a local swap meet. This stuff works better than anything I've tried. Very rusty parts will come out clean as a whistle after soaking for only a couple of hours.
Old Nov 7, 2004 | 08:21 PM
Mike Mercury's Avatar
Mike Mercury
LemansBlue68; thanks for the tip and link
Old Nov 7, 2004 | 08:48 PM
Bake's's Avatar
Bake's
Naval jelly. Has been around for years, for good reason.
Old Nov 8, 2004 | 03:46 AM
grybdn's Avatar
grybdn
although I never treid it, I heard "COKE" and a toohbrush.
Old Nov 8, 2004 | 04:26 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Never worked for me.
Vinegar also left a light carbon film on the old head bolts I tried it on.
Old Nov 8, 2004 | 06:46 AM
Love My 72 and 77's Avatar
Love My 72 and 77
I personally go to the local swimming pool store and buy a gallon or two of muratic acid that costs me about 2 bucks a gallon. This stuff works amazingly well on rust. DO NOT BREATHE THAT SH*T it will make you gag like John Holmes's girlfriend! Now I'm gonna have a salad with vinegar and oil dressing
Old Nov 8, 2004 | 06:47 AM
Love My 72 and 77
You must have been watching that movie "BLOW" with Johnny Dep!
Coke and a toothbrush.......kinda sounds like my old girlfriend
Old Nov 8, 2004 | 08:03 AM
ICEMAN59's Avatar
ICEMAN59
POR-15 sells a metal prep that works really great. I used it on my engine bay, rusted parts came out to bare shiny metal.
To Help! to dissolve rust off parts?
Old Nov 8, 2004 | 09:22 AM
viperjesse's Avatar
viperjesse
http://www.justbrits.com/Articles/electrol.htm
Try this site, Iunderstand it works great.
JZ
Old Nov 8, 2004 | 09:59 AM
mandm1200's Avatar
mandm1200
I used vinegar and it does work. I use a hand held wire brush to clean the dirt and loose rust. I let it soak 24hours and then brush it again. There is normally a little bit of rust spots and it takes and 24 hours to loosen it up.
I do want to point out one problem I had. I soaked the rear spindle flange and bolts for several days. The items cleaned up nice. When I went to torque the bolts during assembly, the first one stripped before I got to 70ft/lbs. It seems that the vinegar took enough material off the bolt threads and flange threads making it too loose to properly torque. I then had to get heli-cores put in. When doing the other side I left the bolts in the flange so the the vinegar would not eat the threads (or at least keep it too a minimum). I then purchased new bolts for both sides. I do not think vinegar is good for a long soaking for anything threaded.
The items will rust very fast if not properly finished. I use Metal Ready, from the POR-15 line of products, as soon as the items are dry. Most of the parts then look like the day they were made.
Old Nov 8, 2004 | 12:37 PM
1971Coupe's Avatar
1971Coupe
I used WD40 on my nuts & bolts, then cleaned them with a rag.
They came out looking like new,
