Big Block Cam suggestions
Old Nov 8, 2004 | 09:58 AM
dfseidel's Avatar
dfseidel
Default Big Block Cam suggestions
Just starting a frame-off on a 1974 corvette coupe. Will be converting to a bib block in the future. Man. trans. Wife and I are considering a 502 or 540 and are trying to decide on a cam. Mostly street use, infrequent trips to the track. Leaning toward AFR CNC 305's, but that is not set in stone. Wife would like some lope, but not so much as to make it a bear on the street. Thanks all!
Old Nov 8, 2004 | 10:46 AM
Corey_68's Avatar
Corey_68
Give us some more info:
expected rpm range
Compression
intake
carb
For what it's worth those 305's would choke a 540ci, hell I'm running 325's on a 468.
Old Nov 8, 2004 | 11:28 AM
dfseidel's Avatar
dfseidel
expected rpm range
Compression
intake
carb
Hmmm under 6K, 9.7, Holley MPFI
Anything else?
I'm not fixed on the heads, so suggestions are welcome!
Old Nov 8, 2004 | 01:12 PM
stinky's Avatar
stinky
dfseidel, go here for some posts regarding my 540ci bbc: http://forums.corvetteforum.com/showthread.php?t=869981 and here http://forums.corvetteforum.com/showthread.php?t=861137
might also try www.chevelles.com and go to Chevelle Tech - Performance, and do a search under '540', there are some good threads about cam options. Mike
Old Nov 8, 2004 | 08:57 PM
Summerfun's Avatar
Summerfun
Stinky,
Those are great threads!
How did I miss out on those?
Old Nov 8, 2004 | 11:43 PM
Simmo's Avatar
Simmo
expected rpm range
Compression
intake
carb
From what I understand, because you are running MP injection you can afford to run a bigger intake port.
Old Nov 9, 2004 | 04:14 AM
Les's Avatar
Les
That's a good suggestion. As a newbie on chevelles.com I hit them up for cam advice & that's how I found the one I'm now running. Lotsa hard core gearheads there.
Old Nov 9, 2004 | 04:30 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
To Big Block Cam suggestions
