BB bore 30 or 60 over
Old Nov 9, 2004 | 11:21 AM
Gage's Avatar
Gage
Default BB bore 30 or 60 over
my 454 doesn't need to be bored, but I guess since it is going to machine shop for cleanup and honing, should I go 30 or 60 over and I think 30 over is 468 cu in but what will 60 over make it? Is it worth the extra power and what will it cost ballpark to bore 60 over
thanks, Greg
Old Nov 9, 2004 | 11:34 AM
norvalwilhelm's Avatar
norvalwilhelm
A 454 bored .030 over is a 460 and .060 over is 468. I would only go .030 for cleanup , that leaves another cleanup on the bore.
In some cases a 454 can go .120 over but that is risky
Old Nov 9, 2004 | 11:36 AM
gkull's Avatar
gkull
4.250 X 4.00 = 454 ci 4.310 X 4.00 = 466.9 ci commonly called a 468.
Additional ci gained by boring is really a very small % and the performance is minimal with everything else being the same. Cleaning up out of round is normaly the reason for over bore.
Old Nov 9, 2004 | 11:45 AM
Gage's Avatar
Gage
thanks guys, I have only bought crate motors in the past so this building engines from scratch is new to me. The engine came with flat tops but with the 049 heads I think the comp will be too low so I'm thinking of a dome piston to get the comp up around 9.5:1, that way if I get better alum heads in the future with smaller chambers I still have room to go up to 10:1
Old Nov 9, 2004 | 12:14 PM
matchframe's Avatar
matchframe
I have the same decision for my 454. I thought about .060 over, but the block really does not need that. If the block is bored .030, that would leave more material in the cylinder which will allow the engine to run a little cooler.
Norval makes a good point in that going .030 over leaves room for another bore thereby stretching the life of this particular block.
www.bigdogvettes.com
Old Nov 9, 2004 | 12:38 PM
markdtn's Avatar
markdtn
The more you bore a block, the harder it is too keep cool. There is less metal to dissipate the heat with. I would go the minimum required to clean it up. It it will clean up standard, leave it standard.
To BB bore 30 or 60 over
