Caliper rebuilding O-ring
My biggest problem, or source of leaking I hope, was that the pistons were too corroded to seal between the piston and the lip seal.
I put new lip seals in the fronts about a month ago, so I know the procedure. This stopped them from (drip drip) leaking for about 24 hrs.
My questions are:
I know to use rtv where the dust boots go on the piston, and on the outside after installing the boot in the caliper, but do you use rtv on the inside. What I mean is where the metal ring of the boot goes into the caliper, do/should you use rtv there, or is there a reason why you shouldnt use it there?
My new pistons came assembled, should I take the o-rings off the pistons and wet them with fluid, or just dunk the dry assembled pistons in fluid before putting them in the caliper?
My calipers have been SS sleeved long ago, and Im planning on leaving the springs out.
Any other tips, or things I should do or not do to get these stupid things to not leak when I am finished would be much appreciated.
My questions are:
You don't say where it's leaking from...could it be where the brake line enters the caliper? Is it all four or only one?
I did the same thing on my 78, replacing the pistons with O-ring pistons and using the existing SS calipers. I removed the springs and run silicone fluid instead of Dot 3 to avoid both the annual brake fluid flushing and concern re the affinity of moisture to Dot 3. Afterward, I drove over 2,500 miles to the 50th celebration in Nashville and than to Hershey and the car has sat for a year...no leaks! My point is you 've got the right idea but something else is causing the leak...just got to pin it down.
Now if the pistons were too corroded to reuse...something is causing that and you've got to figure out if that has been corrected. Moisture causes pitting due to the use of Dot 3 without the recommended annual flushing. You only have master brake cylinder, lines, calipers and pistons. If any single component has lost its integrity...it will eventually infect the remainder of components. My point...RTV is not the solution. I would re-examine those caliper sleeves and make sure they are pit free...if you're leaking from the caliper...something is causing the break in continuity between piston and sleeve.
BTW...yes remove the O-ring, coat with brake fluid and return to piston groove. Keep us posted.
I assume to keep them better sealed for dust, not to keep fluid in.
I think we all know that won't work.
I agree, though - no sealer should be required.
If the new lip seals still leak, you had better check those sleeves
very well. You may have a scratch or pits.
No RTV needed.
Use the supplied grease to coat the o-rings before installing the pistons. Also apply to the rubber on the dust boot before installing them on the pistons. I did not dip the pistons in brake fluid before installing, only used the supplied grease and have not had any problems.
Mike
No RTV needed.
Mike
We suggest leaving the spring in as bobs77vet said. Only the racers take the spring out, and that is on a rare occasion. A few racers have told me that if they take the spring out they can get maybe an extra 1-2 mph on top end but we do not suggest that for street purposes.
Tony
VBP
Ok, my orig pistons are pitted / corroded. I believe that fluid is leaking between the seals and the corroded bits on the piston causing the fluid to fill the area behind the dust boot, then they leak where the boot seals to the piston. Right now both fronts, and one rear caliper is leaking from the piston/boot and nowhere else.
My sleeves are smooth both visually and I can feel no scores or scratches in them.
The cause of the pitting (pistons) I believe is from a previous owner who tried to switch to dot 5 and did not properly flush the system first, so I had a lot of gunk around the pistons, and in the lines. The system has been flushed, and is now clean and clear.
I was not using the rtv as a "bandaid" to stop the leaks. I was using it with new lip seals/boots because I have read a lot of posts here that say to use rtv in the dust boot groove of the piston and to put some around where the boot seals to the caliper. I have also read here that GM started putting rtv on the piston/boot seal in 78'.
68-82 calipers are identical right???
I didn't come up with this stuff (rtv and springs) on my own guys, I got it here.
Quote from my Haynes manual:
On 1978 and later models, before installing the pistons into the caliper apply a bead of silastic sealant (rtv) to the boot grooves in the pistons (the groove closest to the concave end of the piston)
The factory outer seal acts as a weather/debris shield. Around 1978 or so GM issued a technical buletin outlining a procedure to apply RTV silicone to the mating surfaces of the seal and caliper. Cheap insurance, but hardly anybody does it.
GENE
The RTV trick is common and it works, as long as you don't have any brake fluid on the spot where you are trying to get it to stick..... which is highly unlikely in most cases.
The purpose of the RTV is to bond & seal the outer dust boot to both the outer groove in the piston, and to the bore where the metal ring of the dust boot is pressed into the caliper.
Brgds. Gunther
Mike
I guess there are differences in opinion on these subjects, I have no stance on either, I just want to do it the right way and stop the leaks. Hopefully the new o-ring pistons will do it regardless of rtv and springs.
TONY.....VBP: Is the grease supplied with the o-ring pistons for assembly?? I assumed that it was the same stuff you got with new brake pads to stop squeaking between the piston and brake pad.
But if I read your post (the one you quoted) right, I should remove the rings, grease them before putting them back on the piston, and use the grease as assembly lube when installing the pistons in the caliper. Please let me know if this is correct.
"GREASE" as they put it is SPECIAL brake grease NOT chassis grease or wheel bearing grease or anti-squeek grease...use it sparingly OR use brake fluid...........ONLY!!
...redvetracr
...redvetracr
I got a little tube of it for each set of pistons, packaged in a bag w/the dust boots.
Nobody??
Grease???
Tony?
there are many different opinions on how do to things on our vettes, there are also many different people who post ideas with varying degrees of knowledge.... its good to ask for and get opinions on how to do stuff.. for example you asked about RTV.... i didn't use any on my 77 ...however in your case the Haynes manual says to use it....so using it maybe was the right thing for you and your car even though I didn't use it on my 77... so what i'm saying is its ok to get varying answers but only you can sort them out and see whats appropriate....Having said that i do hold in higher regard posts from reputable vendors, their livelyhood depends on providing good quality stuff and they deal with it on a regular basis.... good luck on your repair...
So -1 for rtv and +1 for no springs.
Still dont know about removing the o-rings from the pistons to lube/grease before assembly.
Guess I'll call vbp monday.
The O-ring piston/seals dont develop the memory effect it appears and they are much tighter in the bore, which helps to eliminate air pumping caused by slightly out of tolerance rotors.
Just use DOT3 brake fluid on your piston O-ring seals upon assembly, no special grease is required.
Make sure your mating surfaces of the two caliper halves are spotless and there is no paint on them either. Torque them to teh proper settings and you should have no problems-If the stars are in alignment
PS I beleive most trouble free caliper designs use O-ring seals, so there must be something to this.
Brent.....
), with the springs. I see what WESCH meant about the springs not being quite strong enough to push the O-rings. After a wire brushing and a couple coats of high-temp paint, I'm going to feel bad putting those great looking things back on the less-than-clean car!-=Boston!=-
