DOT-3, DOT-5 or DOT-4 - Which and Why
There seems to be a number of posts lately that talk about calipers, lines, MC and other parts that leak but no one discusses the fluid.
It's my understanding that we're supposed to flush our sytems yearly. Does anyone do this?
Further, i understand that DOT-5 fluid (silicone brake fluid) should eliminate the need for flushing and eliminate brake line corosion. Anyone refute this?
It seems to me that, other than higher cost, I've never heard a reason not to switch to DOT-5. Does anyone know of any?
Last, where does DOT-4 fit in. I see it listed as "Heavy Duty." What's the diff? Higher boiling point? Does this matter?
As I said at the start, let the debate begin!
To sum it up the advantages to silicone fluid (DOT5) is it doesn't attack paint & it is not hydroscopic (doesn't absorb water)
Disadvantages:
compressible at high loads (near BP)
water puddles in system
can be a PITA to bleed
expensive
Some good fluids are:
FORD HD
Castrol SRF
Motul RBF 600
Motul Racing 600
AP Super 600
NEO synthetics Super DOT 610
Suppose I want a good compromise fluid (lowered flush frequency, average feel, average temp tolerance, etc.)...what would be a good choice for the lazy enthusiast?
Disadvantages:
expensive
compressible: not that great for racing use... (how are you driving your car??)
water puddles: have not heard of this, cannot comment..
bleeding - I did not have any problems
expensive - well, it's probably good for three years, so what ? $40 vs $10 every three years ?
It does not eat paint, that's a very good thing !!
I use it only for a few months myself, a friend of mine uses it for 10 years with the same set of calipers and as far as he can remember he never even flushed it... he drives his Vette only 1000 miles/year and never had a break problem since he installed the brakes and changed to silicone fluid ten years ago. It was his experience/advise that made me use it. If my breaks also last ten years then I'm happy...
DOT3 and DOT4 will mix fine, DOT4 being the better of the two. I like using DOT4 because it makes me feel better, even if the gain is marginal. (Cost difference between 3 and 4 where I am is about $.20/quart) DOT5 must be used separatly, and I think many recommend replacing the entire system with new components to switch.
EDIT: I was just thinking, why does DOT5 not necessitate flushing as often? I would think that the same contaminants that get into a DOT3/4 system would just as easily get into a DOT5 system?
):[From Hackney:] The "Estimated BP After 6-months" column is estimated based on a page I found that says brake fluid gains about 3.5% moisture per year, which is where the wet boiling point is measured.
Assuming linear degradation this column is where you'd be. The last two columns may be confusing. They're the price per ounce, divided by the degrees F the fluid exceeds the dry or wet DOT spec; sort of a price for performance number where lower is better. Yeah, I'm an engineer.
FWIW: My conclusion: ATE Type 200 and Super Blue are not only the cheapest of the performance brake fluids, they are also the cheapest per degree of boil protection, and have a very high 6-month BP estimate. In addition you can alternate with each change and the color difference will tell you when you're done. [Note that ATE Blue is not DOT-approved because of the color.] ATE and some of the higher-performance fluids are available from ogracing.com. Valvoline and Castrol are commonly found in mass merchandisers.
Conversions: F = (C x 1.8) + 32
C = (F - 32) x .5555
Fluid 1)Dry BP
2)Wet BP
3)Est. BP after 6 months
4)US $/oz
5)US $/oz per °F > DOT4 (#5 has the a and b)
----------------(1)..(2)..(3)............(4).......(5a) Dry..(5b)Wet
Castrol SRF.......590 518 554........$2.076....$.0144.....$.0100
NEO Super DOT..585 421 503.........0.983.....,0071.......,0089
Motul Racing......600 585 421 503...0.712.....,0051.......,0065
Motul DOT 5.1....509 365 437.........0.675.....,0107.......,0125
ATE Type 200/ATE
Super Blue.........536 392 464.........0.295.....,0033.......,0036
Valvoline High
Perf Synpower....513 333 423.........0.16.......,0023.......,0073
ATE SL..............500 329 415
Castrol LMA........450 311 381.........0.219.....,0547.........n/a
DOT 5 Spec........500 346 423.........n/a.........n/a...........n/a
DOT 4 Spec........446 311 379.........n/a.........n/a...........n/a
DOT 3 Spec........401 284 343.........n/a.........n/a...........n/a
I have never had any significant, if any at all, trouble bleeding the brakes. If you have power brakes, you will probably not notice any difference at all in the pedal. With manual brakes it may not be as hard as good as high-performance hydraulic fluid, but again I've not experienced any problems. The Boos even sat for more than a year a number of times, the 1973 for three years once and always had a good pedal with no leaks.
I primarily switched to reduce maintenance on my brake systems on vehicles I don't drive every day. It has met all my expectations.
Having said all that, I would not use it on a serious racing vehicle because it will expand if the brakes get really hot and due to the closed system increase pressure and begin to apply brake pressure. This is the primary reason that it is not recommended or used in racing vehicles.
I have found the best procedures for using it is to flush the system well; I use isopropyl alcohol, and then flush until clean silicone fluid comes out. Then bleed normally. Silicone does aerate easily, so I pump slowly when bleeding. I bleed them again a day or two later and the results have always been satisfactory. Most important of all, I've never had a compatibility problem or a corrosion problem with any of the vehicles.
Bottom line is it has worked for me for more than 20 years and I will continue to use it whenever it makes sense to me to do so.
GUSTO
http://www.valvoline.com/pages/produ...asp?product=51
Old Henry put a ton of cash into the GT40 program. No stone was left un-turned to win that race.
