Top shot nitrous
Old Nov 12, 2004 | 02:55 PM
BrandonS's Avatar
BrandonS
Default Top shot nitrous
I've been wanting to install some nitrous in my car for a while, but i just can't fit a plate system under the carb.... not enough clearance between the filter and the hood. I only plan on doing a 75 shot. Anyone here have experience with the top shot kit? It seems like the best bet for the amount of power i want to add and the challenges that face me.
Old Nov 12, 2004 | 02:57 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
is that the one that attaches to the carburetor air cleaner stud? it looks really neat in the catalogs....
Old Nov 12, 2004 | 04:03 PM
superfine69's Avatar
superfine69
ttt
Old Nov 12, 2004 | 04:19 PM
BrandonS's Avatar
BrandonS
Yes, thats the one. It seems toooooo simple to install, and solves my clearance problem, so something must be up..... things usually never work out for me!
Old Nov 12, 2004 | 06:12 PM
74ZZ430's Avatar
74ZZ430
You have to be using mechanical secondary (double pumper) carb to use the top shot system. A vacuum secondary carb (quadrajet) will not work because the secondary air valve will not open fast enough and you will be spraying gas and nitrous on top of a partly opened air valve.Not good.
Old Nov 12, 2004 | 07:58 PM
BrandonS's Avatar
BrandonS
Good thing my engine isn't stock and i have a 700DB
Old Nov 17, 2004 | 11:40 AM
MasterDave's Avatar
MasterDave
Moderator
I have the 'TopShot' on my engine and it works great. The only issue is that you need a double pumper carb. The under the carb NOS shooters do not require this however.
Old Nov 17, 2004 | 07:52 PM
ZD75blue's Avatar
ZD75blue
Do you need a double pumper so the fuel flow keeps up with the added oxygen?
Just a ponder...
I've looked at them as well, but for the moment I'm thinking I'll keep the quadrajet
Old Nov 17, 2004 | 08:04 PM
nxfirebird's Avatar
nxfirebird
Just a ponder...
no, because the nitrous system carrys it's own fuel. the best way to do a vacuum secondary carb is to mount the activation micro switch under the vacuum linkage, this way the system doesn't come on 'til the secondarys are fully open! this type of set up slightly delays the system and helps reduce tire spin on dusty stree....... i mean slick tracks!
To Top shot nitrous
