Took the headlight actuator out again
Old Nov 12, 2004 | 03:20 PM
PRNDL's Avatar
PRNDL
Default Took the headlight actuator out again
I did the seal replacement thing on my p/s (<= passengerside, not power steering!! ) headlight a couple of years ago, and it didn't help!! Headlights come up ok, but the p/s is real slow to go down, and has gotten slower. Sometimes it will sit there for a full minute before snapping shut! I was thinking it might be an adjustment of the stop rather than a leak somewhere. I noticed the boot was all pulled up so I took the whole thing out. But, I noticed (how could I have missed this before??) that one of the springs is missing! There are 2 sets of springs - 4 total, and I am missing one. Wonder if this could make it slow to close. Anyway, the actuator holds vacuum real well. I need to check the hoses going into the accuator to make sure they are sucking well. Might wait til after the Peterson verdict to go back to the garage....
Old Nov 12, 2004 | 03:28 PM
jdmick's Avatar
jdmick
I have a similar problem. I just took my 75 out for a spin and came back and the passenger side light was up. Sounds like replacing all the hoses, actuator seals, filter and some tees is the thing to do? Anyway I hope that Jerk Peterson fries
Old Nov 12, 2004 | 05:09 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
PRND21,
Have you checked out the control relays and made sure they are leak free. This could be part of the problem too. Here is a link to check their operations and make sure they are leak free.
http://www.corvette-101.com/
Just click on the Vacuum Trouble on the left side of the page and read up.
Old Nov 12, 2004 | 10:46 PM
C12345's Avatar
C12345
I agree with Eddie 70. Replacement of two out of my three vacuum relays, plus acutator seal replacement were needed to get mine working. A vacuum pump really helps on the diagnosis.
To Took the headlight actuator out again
