Broke Rear Spring
Old Nov 12, 2004 | 11:42 PM
Raydon 3000's Avatar
Raydon 3000
Default Broke Rear Spring
The rear spring on my '70 vert broke. I was just wanting to get some input from you guys on what to replace it with. It's a 350/350 that's been rebuilt. Boared .030 over, a stronger cam, preformer manifold and holley carb. Still running the 11:1 compression. M20 trany with 355's in the rear. I basicly just take the car on cruises with the vette club. I do like to push it every now and then though. I welcome any input on what to replace it with and not do an over kill.
Old Nov 12, 2004 | 11:48 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Mine was rebuilt to L46 specs. I run the 300LB VBP spring. Ride hieght is pretty close to a new spring. I have about 6&1/2 inches of thread on the spring bolts. Stock is 6". Other weight composite springs and the the TRW are just too high. The 300LB gives a nice comfortable ride and even when you get on the gas pedal it still sits OK. Other options are a new steel spring or a dual mount composite. I am pretty sure the 300LB is on sale this week at VBP though.
Good luck.
Pete
Old Nov 12, 2004 | 11:59 PM
BKbroiler's Avatar
BKbroiler
I put a new steel spring on mine. Nine leaf standard type. Cheap, no ride height issues and it works fine.
Old Nov 13, 2004 | 12:26 AM
68/70Vette's Avatar
68/70Vette
What happened when the spring broke? Were you driving the car? Any particular reason why the spring broke? Was it salt corrosion, driviing over potholes? just curious.
I'm replacing my spring with a 360 lbs/inch fiberglass spring. My present spring seems to OK, its a '68 spring. I'd just like to know what kind of failures people have with springsl.
Old Nov 13, 2004 | 01:11 AM
Raydon 3000
I was just driving down a city street in traffic. Took off from a red light. The road had a few patched places but it really wasn't rough. Didn't even get to second gear. Heard a loud bang and then metal draging. Thought it was an exhaust pipe mounting bracket that had broke. Pulled over to the curve. Got out and seen what it was. No corrosion, no rust, no sign of wear, just a clean break.
Old Nov 13, 2004 | 01:54 AM
ewalker302's Avatar
ewalker302
Stop it already.
The back of my mind can't fit another worry in there while driving the vette.
Old Nov 13, 2004 | 02:10 AM
71coupe's Avatar
71coupe
Mine did the same thing a few years ago over some railroad tracks. I went to a 7-leaf spring. Rides a little tighter than the 9 leaf, but it's not harsh & it corners better.
Old Nov 13, 2004 | 12:33 PM
stingr69's Avatar
stingr69
I have the TRW 355 LB rate spring that was installed about 10 years ago. It has the AOS trademark on it. I had it replaced by a Vette shop so I can not say how they got the ride height so perfect but it is. Probably used longer bolts as most people use. The 355# rate is not realy bad at all with the Bilstein shocks but it was pretty bouncy with the GM shocks on there. Other than the need for better shocks I have no complaints. The 355# spring seems to be a good match to the stock base front springs on my 1980. I have also backdated the L-82 engine to L-46 specs but otherwise the car is stock.
Hope this helps.
-Mark.
Old Nov 13, 2004 | 03:29 PM
Raydon 3000
What is this height issue all about with the composite springs? Do they ride higher or lower than the steel? And how do you set them up for the right height and to what spec?
Old Nov 13, 2004 | 04:13 PM
Kid Vette's Avatar
Kid Vette
OK, you asked for it. Read this: Composite Springs - Why So High?
Old Nov 13, 2004 | 07:20 PM
Raydon 3000
After reading through the 17 page post I've decided to go with the 7 leaf steel one. Thanks guys for all the input.
Old Nov 13, 2004 | 07:55 PM
71coupe's Avatar
71coupe
One advantage a steel has over a fiberglass: When mine broke, the clamps held it together. I limped it 15 miles home.
Old Nov 13, 2004 | 08:08 PM
carl a's Avatar
carl a
i have the trw mono leaf and am glad i changed from leafs- i bought 2 sets- the 1st time the shop that installed it broke the cover so i put in a beefed up cover and the 2nd shop put in some cheezie 7 leaf & i didnt like the ride ,,,so when doing the body off i went with the mono leaf and couldnt be happier----also i have the composite springs on my astro van and after 300,000 miles the ride height is still like new..do that with a leaf!!!---
Old Nov 13, 2004 | 08:11 PM
AkMike's Avatar
AkMike
Cruising
Oryou could just have the broken leaf replaced. Any good spring shop could build one and re-arch the stosk ones back to original height. It's no big deal. Metal fatigue is probably the culprit so IMO I'd slap a fresh one in.
To Broke Rear Spring
