Shocking problem
Old Nov 13, 2004 | 10:40 PM
Dk Met Grn 80 L82's Avatar
Dk Met Grn 80 L82
Default Shock Install Question
OK what am I doing wrong. I changed out my strut bushings today and get to the easy part, putting new bilsteins on. The hole in the end of shock is about a quarter inch off (compressed shock too long) with the car jacked up and trailing arm hanging. What is the correct proceedure, top bolt first then bottom, is it normal to have to compress the shock to get it on?
Also, I had to take my fiberglass spring out to get the strut bracket out. I have a VBP spring, I misplaced the papers saying how tight to make it?? Snug, tight, supper tight??
Old Nov 14, 2004 | 08:53 AM
Dk Met Grn 80 L82
Also, it looks like the photo shows the top rear lock washer against the bolt head end not against the nut end. Is that right?
Old Nov 14, 2004 | 09:07 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
are you saying the uncompressed length is 1/4 " too long and that you need to compress it slightly to install it? if so i would think that this is ok....the reason being is that you would not want to use the shock as the suspension restraining device...
Old Nov 14, 2004 | 09:15 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
With regards to the second question, yes. The lock washer goes behind the bolt head. The bolt with lock washer is inserted from the outside and the nut towards the inside.
The first question regarding shock length? When I did mine the suspension traveled further then the shock length and I had to slightly compress the suspension to line up the mounting hole to the lower shock mount. I would recommend checking your new shock length against the ones you removed to be sure you have the correct shocks. The gas charged shocks will fully extend once the wire securing them for shipping is removed. I don't think it would be unusual to have to compress them sightly to install.
Spring bolt torque? Yes, I remember a 3 step torque sequence, but I can't remember the torque values. Maybe someone else might.
Old Nov 14, 2004 | 12:26 PM
Dk Met Grn 80 L82
Thanks for the note on the lock washer. I will recheck the shock length to the old ones today and see if I can find why they seem long.
To Shocking problem
