2nd. Dumb Question
Old Nov 14, 2004 | 01:12 AM
Rhufus's Avatar
Rhufus
Default 2nd. Dumb Question
Charged the battery in the Vette in anticipation of my FIRST cruise.
I jumped in, hit the starter for a few seconds. Turned over like a wild man. Hit again and click...click...click. Played with it a few minutes, nothing.
Well that wasn't going to stop me, so I brought out the jack and jackstand.
I crawled under it and jumpered it out with a screw driver and got it running. Got out from under it, put her on the ground and told my wife to vacate the drivers seat, cause I am "outa" here.
Now for my question.... Any 350 starter work ? Didn't really take a
look-see while I was under there. Are all the bolts easy to get to ? It is a '78 L-48.
Rhufus
Old Nov 14, 2004 | 02:07 AM
Star79's Avatar
Star79
Rhufus
I changed mine in about 20 minutes this summer (79 L-48), bolts were all easy to get to. I think any 350 starter should work, but my parts guy asked me if it was manual or auto so there may be a difference there. I had to remove the bottom flywheel cover thingy bolted to the trans, and angle the starter around the headers on the way in/out. Keep track of where all the wires go, there's more than on a normal car.
Lots of folks recommend mini starters or remote solenoid starters because heat seems to kill Vette starters, but mine has never given me any hot or cold start problems.
Old Nov 14, 2004 | 02:29 AM
ewalker302's Avatar
ewalker302
You prob just need a solenoid. Replace that before you buy a new starter.
Old Nov 14, 2004 | 05:12 AM
Love My 72 and 77's Avatar
Love My 72 and 77
If you in fact need a new starter go with a mini starter they are awesome!
Old Nov 14, 2004 | 09:10 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
\\ especially if headers are in your future...
Old Nov 14, 2004 | 12:00 PM
Rhufus's Avatar
Rhufus
I think I will go with the mini-starter. So far I have come up with $162.50 from a circle track supplier.
I wonder what I would pay for a OEM starter ?????
Rhufus,
a.k.a. Kenny
Old Nov 14, 2004 | 12:09 PM
Rhufus's Avatar
Rhufus
Old Nov 14, 2004 | 12:12 PM
Star79's Avatar
Star79
Rhufus,
a.k.a. Kenny
You could get 4 or 5 rebuilt starters from Napa for 162 dollars.
Old Nov 14, 2004 | 12:37 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Old Nov 14, 2004 | 01:09 PM
exdrag77's Avatar
exdrag77
I know you probably just want to bolt a new one on and get back to driving, but if you remove the nuts off the terminals on the solenoid and remove the endcap, the solenoid can usually be fixed easily. You just need to take the large positive studs out of the cap and rotate them 180 degrees and reinstall all. It isn't a permanent fix, but will get more miles out of the original. Of course with the price of solenoids these days, don't know if it's worth the trouble to fix the old one!
Old Nov 14, 2004 | 11:37 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
GM has a nice smaller, high-torque starter that bolts right in. It was designed (I think) for the 502 BB crate engines. So far it doesn't seem to have the classic heat soak problem, and starts great every time. It sounds kinda funny, though.
Old Nov 14, 2004 | 11:48 PM
Russ Bellinis's Avatar
Russ Bellinis
The other thing to do is to mount a starter relay near the starter. If the Vette is anything like my Firebird, the starter circuit goes through a bunch of connections before it gets from the battery to the starter. Take a Bosche type relay and run a wire directly from the positive battery terminal to the common side of the relay points. Run a wire from the normally open contact to the starter solenoid. Then run your stock starter wire to one side of the relay coil and the other side of the coil to ground. A voltage drop to a small solenoid is not nearly as critical as the it is to a starter solenoid. Put an inline fuse right near your battery terminal to protect from a short circuit. I would use #10 ga. wire from the battery to the starter, and probably a 15 or even 20 amp fuse.
To 2nd. Dumb Question
