Rocker panel install question
Old Nov 15, 2004 | 11:36 AM
Munky's Avatar
Munky
Default Rocker panel install question
Can someone tell me the best way to install rockerpanels on a 68 with hooker sidepipes? Is cutting necessary? How does the fit work with hookers coming down under the panel? I really want to avoid any rattling.
Thanks.
Old Nov 15, 2004 | 12:02 PM
70vert's Avatar
70vert
Banned Scam/Spammer
Some need cut, some don't. If it needs to be cut, make a cardboard template of the forward 1/4 with at least two or the front screw holes. Trim/fit/trim/fit the cardboard untill you achieve a nice fit (1/4" clearance around the tubes will due). Do both sides and transfer the template to the rocker panel and cut. Use masking tape to protect finish untill complete.
