Rustolium epoxy garage floor coating
Old Nov 15, 2004 | 02:32 PM
blackbeauty74's Avatar
blackbeauty74
Default Rustolium epoxy garage floor coating
Hello, I was thinking of coating my new garage floor with an epoxy floor coating. I was wondering if any of you guys have ever used this stuff and if so how great is it.
Thanks in advance..
Old Nov 15, 2004 | 03:05 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I considered using Rustolium but went with www.griggspaint.com as long as you are looking at the two-part epoxy system you should be fine. Just be sure to prep the concrete properly. Clean it good and etch it with muratic acid.
Old Nov 15, 2004 | 03:21 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Many of these coatings are very slippery, this can be a problem on a rainy day when you drive the car into the garage and you hit the wall because of the wet tires.....
Old Nov 15, 2004 | 04:47 PM
mayberg's Avatar
mayberg
I was thinking about the U-Coat-It kits. Once you spend the bucks for two of the Rustoleum kits to cover a 2-car, the price on this doesn't seem to be so unreasonable. And they give you the stuff to give the floor some grip.
Anyone used this stuff?
Old Nov 15, 2004 | 08:29 PM
nd4speed's Avatar
nd4speed
I just put that down for a lady a couple weeks ago, it lokks good but one coat for a top coat was not enough you could see lap marks from doing it in sections. other than that it looks good and easy to apply.
Old Nov 15, 2004 | 08:40 PM
matchframe's Avatar
matchframe
I painted mine with 2 part epoxy. Very durable. I am not sure about the slippery factor because I have not driven on it yet. I started my frame-off rebuild right after painting the floor. It shows some wear after working on it for a little over 2 years, but still has a lot of life left in it.
www.bigdogvettes.com
Old Nov 16, 2004 | 07:45 AM
vetteonr's Avatar
vetteonr
I just used on my newly poured garage floor a couple of months ago and I really like it. It doesn't seem to slippery to me and it's pretty durable. I've done two brake jobs and a shock replacement and it hasn't failed me yet. The best part is you can just spray a little de-greaser and hose it down, and it cleans right up.
To Rustolium epoxy garage floor coating
