what wheels
Old Nov 16, 2004 | 07:41 AM
pferrall's Avatar
pferrall
Default what wheels
what wheels do some of you run? I have a '72 lt-1, and want to upgrade my wheels. I am thinking of going to a 16" or 17' wheel, and would like to stay pretty simple, such as cragers s/s, or TT-II's. I know I need a 4" b/s, with 0" offset. I am hoping somebody in this forum has already done his homework and will be willing to enlighten me. I also need to know if I do go to a larger wheel, what size tire can I go to that will fill out the wheel well as much as possible and also keep my speedo as accurate as possible. Thanks
Old Nov 16, 2004 | 07:54 AM
markdtn's Avatar
markdtn
I have 16" IROC wheels, 4 fronts. Rears won't fit without adapters, and I refuse to use them.
Old Nov 16, 2004 | 07:56 AM
PatsLs1vette's Avatar
PatsLs1vette
I running boys coddington starburst 17x9.5 rears and 17x8's for the fronts with 4 inch bs.Rear tires are 275/50/17's there 27.8 tall and fill the wheel well out nice,the fronts are 255/50/17's.NItto nt -450's.You could run 17x8's all the way around with 255/50/17's and be able to rotate them too.
http://temp.corvetteforum.net/c3/patsvette/dsc01361.jpg
http://temp.corvetteforum.net/c3/patsvette/dsc01365.jpg
Old Nov 16, 2004 | 08:19 AM
lvrpool32's Avatar
lvrpool32
You deffinately need to stick to 4" backspace but this is not 0 offset, offset and backspace are 2 different measurements, as I found out to my cost recently.
Backspace is the measurement from the rear of the mounting flange to the outer lip of the wheel.
Offset of a wheel is a measurement from the centerline of the wheel to the edge of the tire mounting surface.
For example, I have 17 x 8 TTII's....they are 4" backspacing but the offset is -12
If you measure a 8" wide wheel it is actually closer to 9" from outer lip to outer lip, but the tire moutning surface is 8" apart.
I run 255/50 - 17's all around and they fill out the arches quite nicely and I have no speedo calibration issues.
Cheers,
Nick
Old Nov 16, 2004 | 08:22 AM
Twin_Turbo's Avatar
Twin_Turbo
Tires for 16" wheels are getting hard to get, the choice is really limited there. 17s would be much easier.
Old Nov 16, 2004 | 08:26 AM
CGGorman's Avatar
CGGorman
Wheel Vintiques Billet Rallye with argent powdercoated centers 17x9 (or is it 8? can't remember...) with 255/50-17 Bridgestone Potenza RE750's .
Old Nov 16, 2004 | 08:32 AM
LFZ's Avatar
LFZ
CG..those wheels look great! I might have to get me a set of those
Old Nov 16, 2004 | 08:35 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Liverpool,
Those tires in your sig pic are 17's with white letters? If so, that is great. One of the reasons I have been avoiding going 17 is because I love the white letters of the 15 inch BFG's.
Old Nov 16, 2004 | 09:21 AM
lvrpool32's Avatar
lvrpool32
Yup, they are 17's with white letters.........I found a pen that people use to clean up whitewall tires, not the simplest and quickest method...but a good cleaning and patience and two coats and the finished tire looks pretty damn good. They stand up pretty well to, I did them once and washing and driving they still come out good with a quick clean with a cloth.
Nick
Old Nov 16, 2004 | 09:28 AM
comp's Avatar
comp
Nick
what about tire dressings ????
Old Nov 16, 2004 | 09:45 AM
lvrpool32's Avatar
lvrpool32
I'm not into the "shiney" look stuff, I use Endust or Pledge to give a nice satin shine and that does not effect the letters in anyway.
Old Nov 16, 2004 | 10:12 PM
Solid LT1's Avatar
Solid LT1
Here is my LT-1 with it's 16" Torque Thrust II's
Old Nov 16, 2004 | 10:29 PM
litevette's Avatar
litevette
Default wheels
If you are lucky, you can find a wheel store that has a computer program that allows you to "virtually" try out different wheel and tire combinations. Theres one here in town that has it. The program lets you try on different rims, different tires (with different profiles too), see the wheels in motion, change the color of your car and even raise or lower your car. Too bad tire rack doesn't have old vette's or any of the other features I just mentioned. By the way, Lvrpool seems to know a lot about tire profile and spacing so you might want to dig deeper with him.
Old Nov 16, 2004 | 10:42 PM
ICEMAN59's Avatar
ICEMAN59
I am running Intro wheels they have a large selection and custom make them to fit your vehichle, with Nitto /T-450's 255/50/17 front and 275/50/17 rear. The front looks kinda high because the enginge is out but with the engine in they fill the wheel wells nicely
[IMG]
Old Nov 16, 2004 | 11:12 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
70 LT-1 with 17" TTII's and FALKEN ZE502's (245/45ZR17)
http://www.septo.com/vettes/70LT-1/MVC-044X.JPG
and before with stock rally wheels
http://www.septo.com/vettes/70LT-1/MVC-005L.JPG
72 LT-1 with same setup before clean up and detail
http://www.septo.com/vettes/72LT1/MVC-387s.JPG
Bullshark
Old Nov 17, 2004 | 04:04 AM
Twin_Turbo's Avatar
Twin_Turbo
Solid, what are the sizes of those tires?
Old Nov 17, 2004 | 07:31 AM
pferrall's Avatar
pferrall
thanks for the feed back, did you have to use any spacers?I have heard to avoid them .
Old Nov 17, 2004 | 03:50 PM
DropTopBigBlock's Avatar
DropTopBigBlock
Solid, that is one sharp looking car.
To what wheels
