Where to find the date number on my diff?
Old Nov 16, 2004 | 12:28 PM
darrentpi's Avatar
darrentpi
Default Where to find the date number on my diff?
Just wandering where i would look to find the date month year of the diff, I have found some nubers on the diff, but with it being pretty greasy, it makes it tough!
Thanks,
Darren
Old Nov 16, 2004 | 12:30 PM
Larry B.'s Avatar
Larry B.
On the bottom near the spring there is a very lightly stamped ratio code and date code. It is difficult to see sometimes.
Old Nov 16, 2004 | 12:34 PM
problemenko's Avatar
problemenko
The date code is located on the underside of the differential housing. It basically faces the ground. Take some solvent or Simple Green and clean the diff.
Old Nov 16, 2004 | 04:32 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
You did'nt say what year car, but if you have a '75-'79 with a stock rear Y pipe and heat shield, you will not be able to see it. The shield will need to be removed to see the stampings. They will be on the rearmost flange of the diiferential itself-not the "cover" the spring bolts to.
Old Nov 16, 2004 | 11:24 PM
darrentpi's Avatar
darrentpi
It Is A 69, But There Is No Numbers, That Have A 9 In Them Or An 8 At Least, Doesn't Make Sence, Because I Cant See This Being A Replacement Diff, As It So Looks To Be Original With The Amount Of Grease And Grit On It.
To Where to find the date number on my diff?
