Fuel Line Inlet
Old Nov 16, 2004 | 06:10 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Fuel Line Inlet
Ok, I FINALLY installed the carb and intake [Speed Demon/Performer RPM]
The car starts and runs fine, except I have a leak at the fuel line inlet.
I'm not sure why it's leaking. It's on tight, but I suspect I didn't use enough teflon tape.
Any ideas?
Thanks, Les
Old Nov 16, 2004 | 06:24 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
I remember I was chasing gas leaks down for a few days..
check all the fittings, re snug em.. wipe them dry.. bump the starter a few times.. check to see where on the lines it is wet.
keep tightening.. I used very minimal tape
Old Nov 16, 2004 | 06:31 PM
AGVI's Avatar
AGVI
Is is possible to over tighten?
How much tape should I have used? ex: once around the thread, twice?
Les
Old Nov 16, 2004 | 06:53 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Are you using th yellow (gas) teflon tape ?
Old Nov 16, 2004 | 07:06 PM
AGVI's Avatar
AGVI
no, just regular white...didn't know there was a difference.
Old Nov 16, 2004 | 07:17 PM
MotorHead's Avatar
MotorHead
The white tape will disintegrate and leak
Sorry but how's it running anyway ? I did my intake last weekend and I have the dreaded oil leak at the back, gonna try some Permatex #2 on it
Old Nov 16, 2004 | 07:31 PM
AGVI's Avatar
AGVI
Will change to the yellow tape tomorrow. Can I get it at Canadian tire?
By the way, it runs really well, thanks.
Les
Old Nov 16, 2004 | 08:20 PM
MotorHead's Avatar
MotorHead
Sounds good, i think CT has it or try another hardware store
Old Nov 16, 2004 | 08:24 PM
Twin_Turbo's Avatar
Twin_Turbo
Are you using AN hardware?
Old Nov 16, 2004 | 09:30 PM
AGVI's Avatar
AGVI
no, why?
Old Nov 17, 2004 | 12:30 AM
LiveandLetDrive's Avatar
LiveandLetDrive
AN carb fittings are still pipe-thread at the carb aren't they? I suspect redoing the teflon tape and reinstalling will solve it. Even if white stuff disintegrates in fuel, it wouldn't happen that fast would it? 2-4 turns, make sure you are wrapping it the right way. Looking INTO the carb it should be wrapped counterclockwise. That way it doesn't unravel when you install it.
Don't go crazy on it, just good and snug should do.
-Chris
Old Nov 17, 2004 | 01:01 AM
codestar7's Avatar
codestar7
Default Fuel Inlet
The fittings you are using the tape on are actualy called graduated fittings. That means the farther into the thread you screw the female cap the larger the male fitting gets. Its graduated by thousands so realy its more important to have clean threads than teflon tape. Also the best treatment is a very minimal amount of fuel proof teflon paste. Its sold in a tube and is available at most chain auto parts store. The Tape is made for plumbing fittings and realy is not sutible for any other aplication.
Old Nov 17, 2004 | 08:24 AM
MotorHead's Avatar
MotorHead
I have used the gas teflon tape on fuel lines in the past with no problems
Old Nov 17, 2004 | 10:56 AM
AGVI's Avatar
AGVI
so, tape or paste?
I'll try the tape and see what happens.
thanks
Old Nov 17, 2004 | 11:27 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
White will dissolve forming smaller pieces and clog your needle/seat and fuel bowl causing fuel to dump into your carb. Not that I know this from personal experience.
Old Nov 17, 2004 | 11:28 AM
LFZ's Avatar
LFZ
Yellow gas teflon tape...its hard to get it stick around the threads, but it seals very nicely.
Old Nov 17, 2004 | 11:57 AM
AGVI's Avatar
AGVI
minimum 3 wraps...
To Fuel Line Inlet
Old Nov 17, 2004 | 12:00 PM
bracketshark's Avatar
bracketshark
I'm assuming your leak is on the carburator. The fitting that screws into the carb. bowl take a gasket no sealer is needed, where the fuel line screws into the adaptor also requires no sealant because it is a flaired connection. I think there really shouldn't be any tape or sealant used on gas lines, anyway tape is just a thread lubricant to reduce the gauling effect so the fitting can be tightened till the thread interferance makes the seal. The real "seal" lies with the gasket and the flair fitting. Just my thoughts.
Old Nov 17, 2004 | 12:19 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Check the flange on the fuel line and in the carb. Remove all residual tape. Put tape in bottom draw of toolbox. Ever see a new car with tape on its fittings? I am guilty of using tape also but Lars corrected my evil ways.
Make sure the flange fitting is both clean and smooth and the SAME angle taper on both the female (fuel ine) and male (carb) sides. Look for where the tape may have been skewed and possible scoring (scratchs) on the flange. Lube the threads of the nut with some white lithium grease. Also put a dot on the flange where it mates also. Remove the excess grease and wash your hands. Seat the flange and make sure it is nice and parallel then handtighten the nut so that the flange is snug. Using wrenches tighten it up as little as possible to snug it. Test it. If needed snug a little more remembering that you are tightening up on a aluminium carb.
It took me 3-4 times on my last carb to get it to stop. No magic just repeated the above steps. When it is all lined up and the flange seats right the fuel stops coming out.
Good luck.
Pete
Any ideas?
Thanks, Les
Old Nov 17, 2004 | 01:27 PM
CGGorman's Avatar
CGGorman
I don't know about Demon, But Holley dual feeds use inverted flare fittings. No tape needed or recommended...
