Poly Trans Mount causing vibration?
Old Nov 18, 2004 | 01:57 PM
Fevre's Avatar
Fevre
Originally Posted by CGGorman
Additionally, with the pedal depressed (clutch dis-engaged) the crankshaft is spinning and the input shaft of the tranny likely isn't, BUT the pilot bushing/bearing IS. With the tranny in neutral and pedal released (clutch engaged), the pilot bearing is stationary in relation to the input shaft. If there is a problem with the pilot bearing, it may be more pronounced with the clutch disengaged.
Good point.
