Richmond 6 speed
Old Nov 17, 2004 | 09:34 AM
macguy03's Avatar
macguy03
3rd Gear
Default Richmond 6 speed
I am looking for a company that sells a cross member for installing a Richmond 6 speed in a 71 Corvette. My car has the non-removeable cross member. Thanks.
Old Nov 17, 2004 | 09:40 AM
MassVette's Avatar
MassVette
Try
http://www.bowtieoverdrives.com/catalog
They have a C-2, C-3 removeable tubular crossmember for a 700R4 that'll work fine for the ROD.
Old Nov 17, 2004 | 12:45 PM
corvettecris's Avatar
corvettecris
Will that 700r4 xmember work for a tko also?
Old Nov 17, 2004 | 06:23 PM
Older Than Dirt's Avatar
Older Than Dirt
Originally Posted by MassVette
Try
MassVette, don't you have a ROD in one of your cars? Did you use the BTO 700R4 crossmember?
Old Nov 18, 2004 | 08:25 AM
MassVette's Avatar
MassVette
Yep- you've got a GOOD memory!
Actually, they're in both 'vettes. The '79 had a removable crossmember, which made it lots easier. We just welded in a lower mount.
The 67 is a fixed c-member, so I installed the ROD when I put in the engine. I'm gonna make the '67 a removable crossmember too, though. It's much easier to do maintenance that way.
The really good thing about the Bow Tie c-member is that you can run any size or config. exhaust under it!
And Kiesler sells a crossmember kit for the TKO. I just don't like their wide ratios.
Old Nov 18, 2004 | 10:11 AM
Chris Johnson's Avatar
Chris Johnson
MassVette, where did you get the ROD? Does someone have a better price than the $3000 Summit wants?
To Richmond 6 speed
