Here's a pic of my setup. It's dynomax Ceramacoat headers going into 3 inch collectors. They go into 2 1/2 inch pipes with a crossover under the tranny.These pipes connect to the stock 2 1/2 inch stainless pipes which go into Dynomax Ultraflow polished stainless exhaust.
PS: I'm going to be running an H-pipe to flowmasters. Is this something the muffler shop can do with the body off with the right knowledge or should I wait til I get the body on so they can be properly routed?
I have an H pipe on mine. Pictures are on the other computer right now. I had a ball and socket done on mine so it will come apart easily. I'm glad I had it done as I have had the exhaust off 3 times already and plan to take it off this winter for some work. Mine comes apart in about 3 different pieces and does not leak at all.
Gordonm,
Excuse my ignorance but what is a ball and socket? I want mine to bolt together also. I have had my car apart too many times.
Thanks. I have a magnaflow X-pipe still in the box. I think I like that design better. I need to find a way to bolt mine in or change to the Dr Gas style or a H-pipe.
I will have to get on my other computer and send you a picture. Basically they flare one side of the tube so something like a tennis ball will fit snug into it. The other side is flaired slightly larger so when they are together it stay sealed nice and tight. There is a 3 hole header type flange on either side and long bolts hold it together and clamp it. Knid of tough to explain pictures help out.
Adapters on the wheels - I took extra steps in regards to bearings etc. 2 years, many miles, no problems.
Stingry:
I found a better pic, shows the ball connections (2 flanges by diff.) referred to by Gordon. They are a lifesaver for no leaks and quick take apart. Some better pics of the assy. are in the street catalog on drgas.com
Thats a nice setup.
I wish they made stainless ball connections!
Originally Posted by pmazza
Bryan:
Stingry:
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Bryan:
Stingry:
Phil
Did you do a custom rear suspension? I see 2 strut rods on each side
Its a Protofab/Riley 5 link. Same design as Guldstrand. These are the only 2 decent pics I have right now. I should get it on a lift and take some more someday.
