What are you using for an oil pan?
Old Nov 17, 2004 | 05:31 PM
GTR1999's Avatar
GTR1999
Default What are you using for an oil pan?
I'm stripping down the 72 original base 350 and the 5 qt pan has a couple of good dents in it. What pans are you guys using? I think there is a clearence issue on with the vette?
Thanks,
Gary
Old Nov 17, 2004 | 05:43 PM
Gordonm's Avatar
Gordonm
Stock 72 LT1 pan. No clearance issue there. I'm sure you are looking for aftermarket pans
Old Nov 17, 2004 | 07:53 PM
The Money Pit's Avatar
The Money Pit
This is a 7qt Moroso pan. No problem with clearance,but don't let the Jiffy Lube guys change the oil.
Old Nov 17, 2004 | 08:37 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Thanks,
Gary
I use the Moroso 7 Quart pan. The wide kickouts on each side of it make it the same depth as a stock pan...it's supposed to have no more or no less clearance than the OEM one.
Old Nov 17, 2004 | 08:56 PM
kdf1986's Avatar
kdf1986
I have a related question. Can you change the oil pan without pulling the engine out? It seems like if all the bolts are out you should be able to wiggle this out of the backside near the transmission. Do you have enough clearance from the crankshaft then at the front.
I have a 73 454 with a large dent near the oil plug, and it has been welded around that area possible to plug up a hole. I just want to replace it with a stock 454 oil pan.
Thanks for letting me add to this question.
kdf 1973 454
kdf 1986 L98
Old Nov 17, 2004 | 09:45 PM
C3 Stroker's Avatar
C3 Stroker
kdf 1973 454
kdf 1986 L98
Not enough clearance- you need to unbolt the pitman arm from the frame & swing it away.
ZD75blue's Avatar
ZD75blue
Does the oil sit at the same level as stock with that 7 quart pan? All the high performance books I've ever read have stated to run as little oil as possible.
Ever oil study I've ever seen for big diesels says to run as many gallons as you can fit... reduced wear on the oil!
Old Nov 17, 2004 | 09:49 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
let me know what you decide to go with i may tag along....thks bob
Old Nov 17, 2004 | 09:57 PM
kdf1986's Avatar
kdf1986
C3 Stroker,
Thanks for the tip. I will have to climb under the car to see where all the clearance issues are.
kdf 1973 454
kdf 1986 L98
Old Nov 17, 2004 | 10:20 PM
Glassbowtie77's Avatar
Glassbowtie77
I'll be replacing my oil pan this winter also. I have a pretty good size dent in it on the drivers side by the drain plug. I think one of the previous owners tried to jack up the car with a floorjack and missed the cross member. Although it doesn't leak, I don't like the dent being there as I'm sure it throws the oil level off on the dipstick. I checked out Summit for a good steel factory replacement and can pick one up for about $30.00 plus shipping. Nothing fancy, but if you have a base motor this is all you should need.
Old Nov 18, 2004 | 01:13 AM
The Dude's Avatar
The Dude
7-quart Mroso like the one pictured above here.
Oil stays at the same level if you're using the "stock" dipstick, although it now takes 6 quarts or so to fill because of the kickouts. But full is full if you gauge by the stick.
Old Nov 18, 2004 | 03:52 AM
Solid LT1's Avatar
Solid LT1
I use a Canton 240 series road race oil pan. The problem with most aftermarket oil pans is the Corvette pan is only 7" deep stock and most aftermarket pans are 7.5 to 8" deep like a "Camaro/Passenger car" oil pan (including the Summit Chinese oil pan.) Here is a link:
http://www.cantonracingproducts.com/...road_race.html
Old Nov 18, 2004 | 05:22 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
I'm runnin a 7qt Canton Road Race pan. It fit perfect and appears to be a really nice pan
Old Nov 18, 2004 | 06:05 AM
73jst4fun's Avatar
73jst4fun
Thanks,
Gary
I have a new Miloden stock pan from Jegs to put on, seems heavier metal, better baffeling, and better rails than the OEM pan, and has a larger drain hole. The stock pans are 5 quart. I was thinking of installing s larger pan (quart size) but it wasn't necessary, and didn't want to change the pickup on pump....
no clearance issues, just check to see if your running headers that some of the deeper/flaired out pans may be close......
Old Nov 18, 2004 | 08:24 AM
GTR1999's Avatar
GTR1999
Thanks for the response gentlemen,
Here is the pan I have.
I may reuse it. The dent has been in there since I bought the car in 1978 and hasn't leaked yet. The edge of the pan is rolled up and ripped a little- not sure how that happened.
Gary
Old Nov 18, 2004 | 09:20 AM
ZD75blue's Avatar
ZD75blue
Cool
I may have to go with one...
Old Nov 18, 2004 | 09:48 AM
LFZ's Avatar
LFZ
I just learned something....didn't know there was clearance issues. But aren't those 7quart moroso pans with flared out sides 8 1/4" deep? Fitting is ok, i take it..along with ground clearance.
To What are you using for an oil pan?
Old Nov 18, 2004 | 11:04 AM
69autoXr's Avatar
69autoXr
Hey Solid, do you have any oil pressure drop problems when autocrossing with that pan? Also, do you have to use a different pickup with that pan?
Old Nov 18, 2004 | 12:23 PM
The Dude's Avatar
The Dude
Cool
Get the extended pickup that's is sometimes sold with it. It is a little deeper than the stock pan but you won't have any ground clearance issues.
Old Nov 18, 2004 | 12:43 PM
GTR1999's Avatar
GTR1999
[QUOTE=The Money Pit]This is a 7qt Moroso pan. No problem with clearance,but don't let the Jiffy Lube guys change the oil.
Is that the #20180 pan by chance? That's what Moroso recommended as a stock replacement. I have to say their customer service email was very quick and informative!
Gary
