revving the motor up then snapping the throttle plates shut causes a great increase in vacuum.
Turn on your headlights
let em raise
rev her up
take your foot off the pedal at the same time turn off the lights
watch the lights, they should close if the cam is causing your problem.
Otherwise, it could be any number of things.
Sometimes a good lubrication is all that is necessary
Lubrication is the easiest solution so try that
then inspect the condition of your acuators, relays, vacuum tank, hoses, etc.
let em raise
rev her up
Agree - in my case it is the cam causing the slownes
Could be a vacuum leak. I had a 77 once where someone (Bubba) had disconnected the vacuum lines under the dash that control the heater ducts. This caused enough of a leak to cause slow lights. Don't forget that we have a built in vacuum can for the headlights so unless you try to raise them right after starting the engine, the cam should not have that much of an effect.
There are lots of threads on how to troubleshoot headlight problems. Just search on "headlights".
Before you do all that, check the inline vacuum filter, a little white piece of plastic in line close to the intake manifold vacuum source. After I spent 2 hours trouble shooting my headlight system I checked this filter and found it was almost completely plugged. I replaced it and now no worries.
Buy a hand vaccum pump for bleeding brakes (about $30). It has a bunch of connectors that you can check the integrity of each component. Start with your vacuum tank, mine had about 5 holes in it and I got it fixed at a radiator shop. There are miles of vacuum lines (seems like anyway) and you'll need the vacuum layout from one of the threads here. Good luck, it is an ongoing battle for me and my '71. I also have the wiper door that is more complicated than the space shuttle.
It may be dirt. I noticed that on the valve that is located at the actuator is no filter (this is where the hoses are slipped on) - I am not sure if this is supposed to be like this.... it would make sense to have a filter (foam) in this location.
