Solid or soft plan?
6500 red line
600+ HP and very strong on low and midrange torque
Good street manners, 10 years of joy without need to open and inspect every now and then
Strong on strip
Easy later to upgrade to 700+ HP and 7000rpm
Plan:
BG 850 Mighty Demon
Edelbrock BB Victor Jr
AFR 315 Fully CNC ported
Valves with Undercut stems
HydRollerCam ~0.63lift and ~250 @ 0.050
11:1 CompRatio
Forged light aluminum pistons
Total Seal rings
Manley 4340 H-beam rods
Crankshaft Scat (of similar) 4340 steel 4.250 Stroke
540 Dart Big M or World III Race
Have already:
1973 Vette
2” primaries headers
All MSD (6AL, Pro billet, 8.5mm wires, Blaster2)
TH400
3.36 rear gear
What kind of habits would you guess out of this combo?
Something there popping into your mind not fitting into picture?
Where on rpm the peak HP, peak TQ and how much?
Yes the differential/driveline may be a problem, but maybe not with street tires. Without focusing on strengthening I maybe should forget my ET Street´s
My existing 500HP BB does like 12-13 MPG and 10MPG would make no difference to me (figures on easy riding). And it is a toy - I do drive it short distances and around 500-2000 miles a year eq during 6 summer months.
Thanks for your input!!!
The combo looks pretty good, but I'm not too familiar with BBC's. I'd recommend dropping the compression down to maybe around 10:1 and definitely go with a hyd roller cam.
Wanting 600+hp and reliability, a big motor like that is a good way to go. You can also go a tad conservative for reliability and maybe add a small 100-150hp NOS for those times when you want to go for a blast.
The 3.36 gear is probably ok with the torque from the big block, but if it were a small block, I'd recommend maybe a 3.70 gear instead because of the seat of the pants acceleration a simple gear change can make
Why 10:1 instead of 11:1? what would the advantages/disadvantages be?
Dont know why but NOS is not for me...It is like cheating/not real...and to get the NOS here in Finland is difficult...
Best of luck.
Best of luck.
There was an opinion that maybe instead of AFR315 (maybe too small for 540 engine) i should head for AFR335 - what is your opinion here based on 315/502 experience?
What upgrades did you do to your rear end?
"Sneak up on 700 HP" - sounds like this is a never ending story - one newer has enough power
Do you think that based on your figures I should expect like 5800-5900 peak HP? And also I guess the TQ peak might be 200-300 rpm loweer...
I ended up putting offset trailing arms in the back with the 30 spline inner/outer axles and the huge 3.5 inch halfshafts with 1480 series U-joints. I also had the posi rebuilt. I got all those goodies right from Van Steel and believe me it is great quality stuff.
I would think that your HP and Tourque peaks would be at least 300 rpm lower than mine all else being equal. Good luck on whatever you do and I would be happy to answer in more detail with anything I have done. I will say also that I spoke at length with Tony Mamo at AFR and I would suggest you give him a call as well. He designed the BBC heads and is great to talk to.
