Transmission Swap
What are some things to consider with this change? Rear gear is 3:08. I appreciate any help on this.
Also, with a 3.08 rear gear, you need the standard "wide ratio" gear transmission with the 2.64 first gear. A close ratio trans with a 2.20 first gear is too hard to start from stops with.
One other thing I did'nt mention-you'll also need either a "pilot bushing" or "pilot bearing" for the input shaft of the manual transmission.
They have everything you need except the pedals. Also Question for Paul, where did you get the pedals/box and how hard is it to do if you have the entire interior stripped down and the body off the frame?
Bry
My advice for the manual swap...make sure you have ALL the parts you need so you dont have to wait on stuff to be shipped. Its a big pain to have your car out of commission for that long. Also make sure you have jack stands high enough where you can get the transmission out from under the car.
James
James
I could'nt get my automatic cable to "reach" the Borg-Warner speedometer gear. Ordered a "manual" cable, which was about 6 inches longer and it was just enough.
Also, my '75 automatic starter's nose cone would'nt fit into the bellhousing starter opening. Got a manual one & it worked.
For a auto to manual conversion including a 5 speed overdrive , pls see the Keisler thread right on top of the C3 main page ( group purchase ).
They have all necessary parts in a complete kit.
Rgds. Gunther
My muncie is great but.......If I was going through all that pain to install a manual transmission I wouldn't put a muncie in. Either get an OD Auto or an OD 5 or 6 speed. Originality isn't an issue because your carr was an auto anyway right. Nice thin is with that removable cross member you can modify it any way you want to mount a different box.
A 30 year old four speed is fun to drive till you get on the highway. Shop around for the box there are deals out there. What an OD auto. It doesn't take much to fit a later OD auto to those cars.
Pete
Do you have any photos or former posts about your 4 speed conversion? I have just purchased the parts to convert my 76 from another CF member (73 parts)
Any info would be apprecieated
Thanks,
John
