Any one using Gear Vendors overdrive?
Old Nov 18, 2004 | 11:41 PM
Strictly Gm's Avatar
Strictly Gm
Default Any one using Gear Vendors overdrive?
I am installing a "big" big block in a 69 with a 4-11 rear, It is a factory four speed but I want overdrive for the highway, I know most guys here are going for the Keisler unit, But I was talking to Gear Vendors and they make a unit for the Muncie That will give me a fifth gear at the push of a button for about a thousand less than a Keisler unit. Up side I keep the Muncie, downside crossmember cutting and fab. work, and custom driveshaft. Good for racing applications with very high torque numbers. automatic guys get eight forward gears! Anybody have any experience with their hardware or should I go with Keisler?
Thanks in advance
Old Nov 19, 2004 | 06:30 AM
Gordonm's Avatar
Gordonm
For the extra money you get a new transmission and a bigger overdrive. I considered this unit also but went with the Keisler trans and would not go back to the Muncie. I think the GV is a .82 OD and the Keisler is a .68 or the 600 is a .64. With 4.11 gears the 600 unit with a .64 is a great choice. I know someone who just put this in with 4.11 gears and is very happy with it.
Old Nov 19, 2004 | 10:40 AM
Brettmc's Avatar
Brettmc
There was someone over in Arkansas that did this to his vette. Can't remember who it was. A search may turn it up. Anyway, he told me he liked the unit but had to make many, many mods to make it fit.
Old Nov 19, 2004 | 11:15 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Will the OD unit fit in the car? I talked with them at SEMA about doing a unit on a 1979 with a turbo 400 and they said you would have to cut the floor plan, move some stuff around and re-glass the floor. According to them, it was a lot easier than just replacing the crossmember and installing a 700R4.
If my car was a 4 speed manual, I would go with the Keisler unit as well, and keep the 4 speed under wrap in the in the corner of the garage.
Old Nov 19, 2004 | 11:20 AM
Fevre's Avatar
Fevre
Believe motion installed a hone overdrive unit in some of their 4 speeds.
Old Nov 19, 2004 | 12:03 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Thanks in advance
I looked at that also. If it was under $1000 i would buy one.
The $2500 price tag was a little too much if you ask me. One bonus of it which no on has discussed is they can give you an "underrdrive" also. I read about how they put one in a chevy truck or something. The OD can be switched in and out for every gear so you really end up with an 8 speed if you start with a 4 speed. The two gears on the GV "baby powerglide" can be lower and higher meaning you can get out of the whole easier but also have an OD at the top end. Of course if you are switching that puppy and changing gears you will be a very busy boy!
I think the concept is neat but for the money if I wanted the OD I would go with a 5 or 6 speed box or a OD autmatic.
Old Nov 19, 2004 | 12:05 PM
ZD75blue's Avatar
ZD75blue
I'm remembering the same thing... Maybe a handle on the passanger side floorboard that engauged it?
Old Nov 19, 2004 | 12:32 PM
MassVette's Avatar
MassVette
Thanks in advance
You can get a Richmond close ratio 6 speed with 3 choices of overdrive- for a lot less than the Kiesler setup. Plus, it's the same overall length, same driveshaft, same input shaft, same bellhousing flange, and the shifter comes up in the same place. I've had one in my 79 with a ZZ/502 for 4 years- without any incident whatsoever. Great transmission, IMHO!
Old Nov 19, 2004 | 12:42 PM
WESCH's Avatar
WESCH
Hi
Can you supply more info on this, pls. ?
I am strongly thinking about a overdrive manual gearbox and don't mind working a bit harder to install it in regards to the Keisler kit.
I have a 427 CI BB with 3.70 rear end.
Rgds. Gunther
Old Nov 19, 2004 | 01:25 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
anyone have a website for gearvenders
Old Nov 19, 2004 | 02:05 PM
Gordonm's Avatar
Gordonm
http://www.gearvendors.com/
Old Nov 19, 2004 | 02:34 PM
Chris Johnson's Avatar
Chris Johnson
I've seen the ROD at Summit and Jegs for about $3000. Is there a better source? I had read abouth the ROD before on the forum, but can't find those old threads because of the search problems.
Old Nov 19, 2004 | 04:18 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Now that Keisler is in the Corvette Trans swap out business it will be intresting to see what happens to pricing. Richmond has in my mind hosed Corvette owners since they came out with their swap out unit for the 4+3 C4 owners it is basicly the same unit as the ones the make for other applications just about a 1,000.00 more for the special tailshaft for ther C4 application. Keisler's price comes in about the same range. I have heard both pluses and minuses about the ROD 6 speed some say they love them others can't wait to pull them and go back to what they had. I have a C4 that I want a 6 speed for and I'm going to sit back and watch what happens to pricing in about a year. The Keisler sure looks slick. (just my .02 worth)
Old Nov 19, 2004 | 05:59 PM
djunod's Avatar
djunod
That is contrary to feedback I've received from people that have actually installed one. The only modification being the shortening of the driveshaft... keep your original driveshaft and have a new one fabricated.
I was planning on installing one in my Maco... before I ran out of budgeted money for this years' round of modifications... maybe next year.
Old Nov 20, 2004 | 08:36 AM
MassVette's Avatar
MassVette
The Keisler 6 speed for the C-3 is almost 5K.
Old Nov 20, 2004 | 09:01 AM
ZD75blue's Avatar
ZD75blue
I'm pondering going with a track three speed...
The gear vendors unit is an OVERDRIVE... and UNDERDRIVE unit!
Old Nov 20, 2004 | 11:32 AM
stingr69's Avatar
stingr69
And it looks like this
-Mark.
To Any one using Gear Vendors overdrive?
