Shocking Info
Old Nov 19, 2004 | 08:17 AM
uabfan's Avatar
uabfan
Default Shocking Info
Hey, ya'll,
I'm in the middle of re-bushing, my 71-350-auto. Also changing the bearings, u joints, etc... I need some advice on what shocks to buy. I am no racer. My vette is basically a street cruiser. Any advice would be helpful!!
Thanks,
Bill S
Old Nov 19, 2004 | 11:31 AM
page62's Avatar
page62
KYB Gas-a-just. Monotube gas shock. About 27 bucks at Summit Racing. Cheap but effective.
Old Nov 19, 2004 | 12:12 PM
JJ Deuce's Avatar
JJ Deuce
I'm running the KYBs too. For what you're describing, you'd be happy with them, too. I'm sure someone will pop in soon and tell you to buy the Bilsteins though.
Old Nov 19, 2004 | 12:13 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Buy Bilsteins
Old Nov 19, 2004 | 12:16 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Do you have a fiberglass spring or steel spring? Gas-A-Just for steel springs and GR-2's for glass springs.
Old Nov 19, 2004 | 12:17 PM
JJ Deuce's Avatar
JJ Deuce
Hmm. My car had gas-a-justs and a glass spring when I bought it. Sounds like I need new shocks, too.
Old Nov 19, 2004 | 02:35 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Running the Koni's here. I like the adjustablity of the shocks, you can tune them to your liking. There are other shocks now on the market that you can tune while the shock is on the car. Koni's have to be removed to adjust. I had a set of KYB's on mine and found them too soft for my tastes.
Old Nov 19, 2004 | 03:43 PM
75rag4sp's Avatar
75rag4sp
Originally Posted by MotorHead
Buy Bilsteins
I agree Buy blisteins
Old Nov 19, 2004 | 03:58 PM
i885744's Avatar
i885744
bilsteins if you don't care about money. Koni's if you do.
Old Nov 19, 2004 | 04:01 PM
HDFLH67's Avatar
HDFLH67
I have a set of used rear (only) Bilsteins in very good condition. $60 plus shipping for the pair. Love the Bilsteins!
Old Nov 19, 2004 | 05:06 PM
goinbroke's Avatar
goinbroke
...Or another way of looking at it.......Bilsteins if you're single......Koni's if you're married......and Sensa-tracs if you're married and on an allowance.
Old Nov 19, 2004 | 06:45 PM
Twin_Turbo's Avatar
Twin_Turbo
Are the Konis cheaper than the Bilsteins? I think the bilsteins are about 275$ for 4 as where the konis are 200$ for only 2 shocks. For C3s i think only the orange (red) adjustable classics are available and not the **** adjustable (**** on top, only rebound adjustable) yellow sport shocks.
Bilstein uses a different approach to shocks than other manufacturers of oil shocks, they have a gas cylinder that is pressurized so that the oil will always be under pressure and is less likely to foam under heavy operation, this is nice but it also means that the shock is a little stiffer than a comparable shock of the same valving. Because of this pressurized system bilstein uses high quality seals in their shocks, they can be used upside down (unsprung weight although I don't see anyone here running theirs upside down, it wouldn't even be possible on the front)
The konis have an adjustable rebound setting, most street shocks are pretty soft on bump to give a smooth ride and road contact but are stiffer on rebound so that the car won't bounce.
Old Nov 19, 2004 | 07:53 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
KYB Gas-A-Just.
Bilsteins are too expensive for nothing.
Take the money you save and retire!
Old Nov 19, 2004 | 09:40 PM
jdmick's Avatar
jdmick
I just ordered KYB G-2's from Summit for my 75. $17 each. Are they much worse than the adjustable ones?
Old Nov 19, 2004 | 10:23 PM
trw's Avatar
trw
I used the Delco Gas Shocks on mine. Just a cruiser, but they seem to work for me.
A supporting vender also.
Zip = Delco Shocks
Terry
To Shocking Info
